question turbo gurus - Boost Forum
Wednesday, November 02, 2011 7:10 PM
Ok guys when I dug my Saab stuff from the closet I looked at the exhaust side and seen this.... A slight oil residue on the turbine... Is this a bad sign? From the guy I bought this from never installed it and said it was cadw24 old turbo and I contacted Chad about it and he said it has around 30k on it. Is this bad? I hope not....
Re: question turbo gurus
Wednesday, November 02, 2011 7:46 PM
could have been a little blow by, could have been from running rich. how does it spin? only way to know is to try it out and see how it performs. or send it away to rebuild and know its right...
Wednesday, November 02, 2011 9:40 PM
Oh it spins freely and very very small minute amount of play
Thursday, November 03, 2011 12:00 AM
Yep, could have been an engine issue from the previous owner as a number of things can cause oil residue on the turbine.. If shaft play feels ok and it spins smooth, toss it on and give it a spin (no pun intended). You will know pretty quickly if you have a seal issue because you will be smoking
Thursday, November 03, 2011 12:08 AM
Thanks guys
Thursday, November 03, 2011 6:36 AM
i would rebuild/reseal it just in case. as with all used stuff you never know. it would be easier to rebuild it now instead of after you install it
Thursday, November 03, 2011 6:45 AM
mine was like this right off the saab I pulled it off. It will smoke a little when you fire it up too! don't worry after 15 miles mine has been fine for a year.
Thursday, November 03, 2011 6:50 AM
Mine had oil like that when I pulled it off once, ran it for a bit, smoked for a while then it cleared itself up.
Thursday, November 03, 2011 9:37 AM
Thanks Jason and Andy that makes me feel better about it.
Thursday, November 03, 2011 3:48 PM
[ion] C2 Online
mine looked like that and it ended up being 100% fine, it's the most perfect example of correct shaft play ever
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Thursday, November 03, 2011 7:30 PM
Nice thanks ion
One more question on the oil feed I'm using the stock one. Do you put a washer on both sides of the line since it's a banjo bolt. Also on that little nipple on the housing do you cap that or would it be ok to run a line from that to the wastegate since it won't have vac?
Friday, November 04, 2011 12:31 AM
Talking about the port on the bottom
Friday, November 04, 2011 11:44 AM
Cant remember if mine had a washer under and over.
my turbo didn't have that port.. sorry
Friday, November 04, 2011 11:56 AM
[ion] C2 Online
If it's a banjo bolt you need to seal both sides... 2 washers. I can't see pictures of it so I can't say definitively.
650 whp / 543 ft-lb
@turboalero
Friday, November 04, 2011 1:16 PM
jason norwood wrote:Cant remember if mine had a washer under and over.
Weird was yours the Garrett or mitsu?
Friday, November 04, 2011 3:53 PM
Copper Crush washers, and yes cap that port off on the bottom side
Friday, November 04, 2011 6:57 PM
Yeah but on the washers do you put one on top of the line,and one on bottom?
Sunday, November 13, 2011 8:55 PM
For all that's curious the turbo is fine zero smoke on start up. Also I used the nipple on the compressor for the wastegate.
Monday, November 14, 2011 7:03 AM
Mine was a Garrett.
Monday, November 14, 2011 10:07 AM
jason norwood wrote:Mine was a Garrett.
That explains it then. Mine is the Mitsubishi td-04
Monday, November 14, 2011 2:24 PM
Yeppers.
