Boost drop - Boost Forum
Boost drop
Thursday, October 06, 2011 1:48 PM
So I've noticed lately when accelerating and I watch my boost gauge that around 5500 rpms it drops from 14 to 4 and won't go any more. I checked some connections and vacuum lines and its still doing it. I thought maybe my wastegate? But I would like peoples opinions.
Re: Boost drop
Friday, October 07, 2011 7:04 AM
supercharged? if so possible slipping belt.... leaking bypass valve.
Re: Boost drop
Friday, October 07, 2011 7:08 AM
Need more info on the setup...
Size turbo, what type of controller. it COULD be the waste gate opening up to early and bleeding it all off...
Re: Boost drop
Friday, October 07, 2011 9:32 AM
Oh I never thought about that. Ok I have a 60mm precision turbo with an aem Tru boost and a 38mm turbonetics open dump wastegate. I think right now I have it set so it starts cracking open about 5lbs. But since I put this new turbo on its been doin this so maybe I should up it to like 8 or so.
Re: Boost drop
Friday, October 07, 2011 12:18 PM
What spring is in WG? Sounds like the duty cycle is off...
P&P Tuning
420.5whp / 359.8wtq
Re: Boost drop
Friday, October 07, 2011 12:46 PM
What do you mean?? And I have the deltagate so its one spring just adjustable.
Re: Boost drop
Friday, October 07, 2011 1:36 PM
tony buntjer wrote:What do you mean?? And I have the deltagate so its one spring just adjustable.
You have alot to learn.... And its not just 1 spring.. There are different springs/shims used for wastegate pressure. You need to take the wastegate apart and see what color paint is on the spring to identify base pressure.
P&P Tuning
420.5whp / 359.8wtq
Re: Boost drop
Friday, October 07, 2011 1:48 PM
Oh you meant wastegate duty cycle correct? Well have you ever seen the turbonetics deltagate? Because u adjust the nut on it to compress the spring so u don't have to swap them. When i had it apart their was no color on it. I also was watching my a/f today and when this happens it drops down to 10.1-10.4 and I can't understand why.
Re: Boost drop
Friday, October 07, 2011 8:38 PM
My wife has a Deltagate... She has a 10-12# spring and a few shims in it.... I know what you mean by thre adjustment screw, but that doesn't mean you should not change the spring... Do you have a log of this happening? Mind sending me your file to take a look?
P&P Tuning
420.5whp / 359.8wtq
Re: Boost drop
Friday, October 07, 2011 9:02 PM
Man I don't have a log of it otherwise I would be happy to. I was just watching my wideband. I'll be around 12.3-12.6 then all of the sudden around 5500 rpms boost drops down to 4lbs if that and my af drops 10.1-10.3. I thought maybe my @!#$ty fmu was messed up but not certain.
Re: Boost drop
Friday, October 07, 2011 9:58 PM
Ryan, does his car have to be unlocked in say my hpt for it to be logged or can it be logged with just the hpt box and vcm scanner?
Re: Boost drop
Saturday, October 08, 2011 3:33 PM
I can't seem to figure it out I've been looking for everything and don't know what to try.
Re: Boost drop
Saturday, October 08, 2011 8:04 PM
BuiltNBoosted wrote:Ryan, does his car have to be unlocked in say my hpt for it to be logged or can it be logged with just the hpt box and vcm scanner?
Nope.. Only needs to be licensed to edit file...
P&P Tuning
420.5whp / 359.8wtq
Re: Boost drop
Saturday, October 08, 2011 10:14 PM
ill see if next time im home, i can try to take a log or something.
Re: Boost drop
Saturday, October 08, 2011 10:32 PM
Ya vince I would owe you major!
Re: Boost drop
Sunday, October 09, 2011 12:38 AM
I wont be back to my rents til the 17th i think it is. then we need to find a laptop that I can get HPT installed on thats reliable...
Re: Boost drop
Monday, October 10, 2011 8:02 AM
did you check your bov? it maybe pushing it open under high boost causing the drastic boost drop.
Re: Boost drop
Monday, October 10, 2011 5:08 PM
Well I checked the vacuum line to it and that seemed ok so maybe I should take it off and look.
Re: Boost drop
Friday, October 21, 2011 10:15 AM
Boost guage with vac on it would help here!
Re: Boost drop
Friday, October 21, 2011 11:07 AM
I have the aem Tru boost and its got the vacuum line right to the gauge.
Re: Boost drop
Friday, October 21, 2011 2:06 PM
Get a computer set up with HPT and ill be home in a week and we can use my cable to scan it.
Re: Boost drop
Sunday, October 23, 2011 7:35 PM
Exhaust Restriction... mine did the same when my flexible had shinked to 3/4'' hole (Inside diameter)
Boost Lover
Re: Boost drop
Sunday, October 23, 2011 7:48 PM
Before you do anything...
Does the tru-boost act as a boost controller? If so I would take that out of the equation and just run of the gate spring and see if you see the same drop. It sounds like its a control issue if it drops that quickly.
