did the boost leak check to my car and i found that the injector seals leak at around 5 psi want an idea so need some help. should i just change or should i put gasket glue on them?????
I would change the o-tings.
What injectors are you running?
stock about to upgrade to 550 rc
i had the same problem when i first set everything up... if its the seal at the bottom of the injector itsef just go to your auto parts store and buy new ons they are like 6 bucks.... if you cant find cavalier seals use lsj seals they are the same seal.... but if the cup is leaking ac delco makes a complete f/i seal kit with new cups seals and clips that was like 21 bucks.... my 60# injectors all sealed but one so i changed the grey cups and they sealed fine... just remember when you change injectors chances are they wont be the same length well 9 times out of 10...zzp has a hell of a deal on siemens 60# injectors...
