As the title says this might be a dumb question but is there any conceivable way a supercharger from an LD9 (m45 I believe) could be fitted to an Eco? I was just pondering the idea the other day but I know nothing at all mechanically so I figured I'd get a solid yes or no answer here
www.driftnamiperformance.com
Why? The M62 setup trumps the M45 in every way.
its an old concept. time for something new to take the reigns. - Z yaaaa
m45 is cheaper isn't it? Maybe he has one laying around? If there is a manifold for it or you can make one I would think it would work?
Because the M45 is a 1 piece unit (manifold and charger), no.
I'm sure if you could weld aluminum you might be able to swap flanges on it, like that one member did with his H.O. quad mani on his eco. But you also have to worry about belt alignment issues then as well......for the hassel I'd just go the mp62 route
Ok perfect, that's about all the info I need, scratch that idea then
right it a stupid question
JBO since July 30, 2001
