i have a 97 cavalier with a 2.2L and im deciding to turbo and havent figured what size injectors i should use and what fuel pump to use any ideas for me ?
factory should be good up to 12 psi
what????? factory injectors are good for no boost. why would you state that? injector size is determined by how much hp you want to make.
150hp will require 30# injectors
200hp will require 40# injectors
250hp will require 45# injectors
300hp will require 55# injectors
these injector sizes are based on a 43 psi static fuel pressure.
sorry but when i read ur sn i thought of someone doing a hot carl.
gmanz24 (The Bash Whore) wrote:sorry but when i read ur sn i thought of someone doing a hot carl.
LMAO, I did too! BTW, to the OP..... You have side feed injectors, so you will need to do a top feed conversion.... Have fun!
![](http://i3.photobucket.com/albums/y57/imphat0260/IPon19s/Signatures/QWKLN2-2.jpg)
P&P Tuning
420.5whp / 359.8wtq
