ok so i'm trying to hook up my wideband in my 01 z ld9 and don't no where i should hook the wires up to there is 4 wires power, ground,and theres a white wire 0-5 output and a blue serial output wire where do these wires go cant find anything on it if anyone could help me it would be greatly appreciate it thanks
They have detailed instructions on there web site. Not sure why you wouldnt look there, not rocket science here.
"Straight roads are for fast cars, turns are for fast drivers"-Colin McRae
Power goes to a constant 12v
Ground to obviously ground
White wire is for logging
Blue wire? Hm dont remember a blue on on mine.
Like said above, should of came with directions.
WHITECAVY wrote:Power goes to a constant 12v
Should be a switched 12v for the red David. so it only comes on when the key is in the run position.
Yes^ You are correct lol. My brain was still thinking about the blue wire he mentioned that I really cant remember
2012 numbers - 4SPD
AUTOMATIC!!
Here's a Google Quick view pdf link.
Confirm that your serial number on the wideband is the same, I believe it is. Mine is different, as I do not have a Blue wire, but instead have a white/brown combo for the External EIO Datalogging.
AEM UEGO Wideband PDF 10-4100
Red - Switched (In my setup I ran a 10A fused directly from the battery to a flight toggle switch for my power wires)
Black - Ground (Clean ground, bare metal...I used the nut on the shock tower)
White/Blue - Analog/Serial outputs.
Very simple install, but I am kinda surprised that this unit didn't come with a secondary lighting wire to hook into your dash lights for the daytime and nighttime lighting modes.
Erik Nyman wrote:Here's a Google Quick view pdf link.
Mine didnt come with a secondary lighting wire either. Lighting is not really needed as its a red digital diplay for a/f numbers and then the sweeping lights around the gauge.
Like this
http://www.aemelectronics.com/wideband-air-fuel-systems-15/digital-wideband-air-fuel-gauge-25/
White and blue dont need to be hooked up to anything unless your doing data logging with something like HPT
red obviously you want a ignition controlled 12v source
black ideally you want grounded to the same ground as your pcm for minimal "noise"
![](http://registry.gmenthusiast.com/images/matt38y3/sig.jpg)
