What did you guys wire your pumps to? Do they turn on the minute your key does? Key on engine off? key on engine running? Wired to a switch?
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
bump anyone?
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
I just wired mine into my Fuel pump fuse wire in the fuse box under the hood. turns on when the car is on and doesnt come on when the key is turned back
M62 KIT for sale PM ME
I think i wired mine in with the radio.
its an old concept. time for something new to take the reigns. - Z yaaaa
you wired it with the radio?!?!?!?! WHY???
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
The radio always has power when the car is on, plus it can run without the engine running. Also in the odd chance the it shorts out the circuit, i'd rather lose my radio than fuel pump.
yeah good point tinkles never thought of that.
the kits coming off this spring anyways.
i'm tied in the pink wire under the hood. i can run the pump after the car is not running (between autox runs).
this is the start of my signature: have you read the
RULES yet?
my carDomain updated 6/11/10 Forged and Supercharged
if you use the fuel pump wire to trigger a relay to turn the pump on its not going to draw enough current to pop a fuse. its only powering a relay.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Mine turns on with key on engine off
z28guy(KGM BEOTCH)
I think im tapped into the pink wire too, but under the dash.
