saab vaccum hoses - Boost Forum
saab vaccum hoses
Friday, February 25, 2011 9:00 PM
Wondering where people with the saab kit are routing vaccum for the bov and wg. I read bill's post below about my aftermarket fpr being run to the compressor housing, and the wastegate to intake but what about the bov??
thanks
jason
Re: saab vaccum hoses
Friday, February 25, 2011 9:14 PM
listening to more input, because I'm a bit foggy on how mine was run last time.
I think i had one from the fuel rail to a tee from the wastegate/boost valve going to a nipple on the intake. Then the wastegate to a boost valve (this is where i can't remember) and the bottom of boost vavle fed into another tee, going to the bov on the turbo.
It's hard to explain, but I think that's how it was.
Friday, February 25, 2011 11:33 PM
Just give them both vac. Not a big deal really.
Saturday, February 26, 2011 6:48 AM
That's what I was thinking too after I thought about it. Just tee them off to one vacuum.
Saturday, February 26, 2011 8:04 AM
Mm bill says to not let them share vaccum because they bleed vaccum and it will screw with the fpr
Saturday, February 26, 2011 9:22 AM
Never had a problem
Saturday, February 26, 2011 8:15 PM
slocav you are from k-zoo? what tuning are you running ? the reflash?/
thanks
Saturday, February 26, 2011 8:17 PM
I live in kzoo when I'm at school, but home is in the thumb area. And yes just the GM reflash
Saturday, February 26, 2011 8:26 PM
ok so your sayin tee the bov and wastegate together and run the fpr to the compressor housing or where are you running your fpr? i have a aeromotive lt-1 style
thanks
jason
Saturday, February 26, 2011 8:33 PM
Alright I tried to do this with my touchpad on my laptop...it's on paint.
This is what I remember, the car is in 1000 pieces right now, but I am almost positive this is how it was.
Saturday, February 26, 2011 9:14 PM
ok so you basically used 1 source ti run all 3.
thanks
jason
Saturday, February 26, 2011 9:17 PM
Yup, never had a problem. Then ran a hose from the pvc on the valve cover to the one on the turbo.
Hopefully someone else chimes in for some reinforcement.
Monday, November 11, 2013 7:32 PM
Old post, but can I use a oil catch can between valve cover and compressor?
To prevent oil going through turbo and intercooler.
And would a vacuum tee manifold (vacuum log) be a wiser choice instead of tee'ing off to wastegate, bov, & fpr? So connecting all 3 (+ boost gauge) to a vacuum manifold.
instagram: peru_stylez
Tuesday, November 12, 2013 9:54 AM
yep just get a good one and make sure it has a vent on it otherwise you are pressurizing it...
