i searched and found answers but not all of them
are all the fittings the same. i got a turbo off a 07 wrx wanted to know if the fittings will screw right in or are they diff sizes cuz the oil lines i see have the fittings on them all ready
help and answers thanks im at work so cant give turbo specs but will when i get home
*****BLAME IT ON THE ALCOHOL*****
You need to find out what size the fittings you have vs the fittings you have on these lines? Asuming you have some pre made lines? Or are you talking about the ones that came with the turbo? Cant really help you unless we know what size fitting you have. Not totally understanding what your saying here.
"Straight roads are for fast cars, turns are for fast drivers"-Colin McRae
There are quite a few different possibilities when it comes to oil feed/drain setups. Maybe you can post up some pics? Or you may be better browsing some Subi forums.
danm should of got the mitsu turbo the drain i got i just need the fitting that gose in to my turbo i dont know wut size it is
If you can't figure it out, bring the turbo into your local hardware store and start guessin w/ bolts. First learn if its metric or standard, then work on size then thread pitch. This may take thirty min or so but you'll find out what size the hole is. I did it for alot of stuff like the downpipe and wastegate flange bolts too.
"Vroom."
"Yo I wouldn't race him, there's not even an interior in his car man."
"Vrooooooom PSSSSHHH!"
"Oh sh*t. F*ck that, dude..."
"Vroom."
07 wrx, if it's not an sti turbo it should just be a regular old td04. If it's an sti turbo it's a vf39, I think. Are you asking about thread pitch for where the lines go into the turbo, if so I believe all the td04s have the same fiitings. Oil feed is m10 x 1.25 and the coolant ports are m12 x 1.5, the oil drain is a flange.
yeah thats wut i ment mike and it is a td04 i got the coolant ports with the tubes on them . my next question is do i got the run the coolant also
