It's okay to clock the Saab turbos right? So I can point it up instead of down??
Thx
jason
I am unsure if you can or not. But i wanna say no, because of the wastegate mounting. If your running an external gate somehow, go for it. If your keeping the stock wastegate, The two bolt holes for the mount would rotate around.
Didn't think of that wastegate problem. Wanted to avoid using a u bend right outta the turbo!
Anyone on here running the Saab turbo with a ext gate?
Are you trying to run the hot side on top? Auto tranny? I found it alot easier to go at it from underneath.
Hot on top???? Umm no. Trying to clock the output of the turbo up instead of down. Yes auto tranny
hotside is the outlet
JBO since July 30, 2001
