I was wondering if anyone could tell me if you can use BOSCH style injector's on a DELPHI style injector system? I was wondering if it is just a matter of clip's or doe's it have to do with the PCM? the fuel rails in 96-02 2.4L are the same correct?
Friends Don't Let Friends Drive Stock!!!!!
Well I have the Accel 30LB. (310cc) high impedance Injector's, but there Bosch style like the 96-99 (2.4L)? I'm trying to find some suitable injector's for my supercharger kit that I'm piecing together,I already have the proper RC engineering 440cc injector's but I know they won't work well until I get the HP tuner's software to properly tune with them.
either set your gonna have to cut the plugs , and put new 1's in
So its just a matter of buying the plugs, cutting old one's off and wiring on the new ones,................is there a certain procedure to do this?
Thats what I was hoping to hear, now will the RC engineering clips work with anything other then the RC Engineering injector's?
they are all standard for the 98-older style
RC Eng injectors are Bosch style IIRC as are the Accel. I had to cut off the stock plugs and solder on some new ones when I installed my turbo kit. Took us like 10 minutes to do.
5K PB: 24:50
10K PB: 54:26
Team Vision Racing (aka hypsy) wrote:RC Eng injectors are Bosch style IIRC as are the Accel. I had to cut off the stock plugs and solder on some new ones when I installed my turbo kit. Took us like 10 minutes to do.
Does it matter which wire goes where in the new plug for the injector?
make sure you soldier and dont crimp, and use heat shrink. If the injector harness is setup like all the other one's I've seen, there'll be one wire thats common to all the injectors and 4 wires that go to the individual ones (and obviously need to go to the right ones).
Sponsored by:
Kronos Performance
