What are those the the H/E running coolant wise?
Straight coolant? 50/50 coolant/water?
ANy other options?
Mods: Synapse Charge Piping, Short Throw, Bad-Mab Dp, Dejon Intake, BYT Tuned!
Parts For SALE! Pacesetter Header(ECO),17'in Resonator, Alternator, Starter, Viper Alarm.
I'm gunna say mine is around 80 coolant, 20 water right about now, seems to be working good.
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
when it stays above freezing I'm 100% water but when it gets below freezing I'm 50/50
I'm about 80% water 20 coolant.
Coolant is more for the lower freezing point (antifreeze) anti corrosion and to lubricate the water pump. So if your in a warmer climate above freezing I would use mostly water.
13.3 @ 106 mph Cammed
Just to chime in ..... Is anyone using "Redline Wetter Water"?
I put it in my DD just for giggles and it dropped the coolant temp by like 2-3 needle widths on the gauge.
I have a 96 DD and the gauge would read completly vertical (middle of the gauge)
now its a little to the left (on the cooler side)!
It actually worked .....
I might try it in my Boosted 2200.
If i dont like it, my drain is very easy to get to on my custom radiator.
I run 50/50 in the winter. I plan on running water and water wetter this summer in my cobalt. That coupled with an ice box should help things cool, especially at the track!!
Good info, I live in md and it warmer now, Maybe i'll do 90% water and the other 10 coolant, or the water wetter! can you buy that or do you have to order it?
slvrblit wrote:I'm gunna say mine is around 80 coolant, 20 water right about now, seems to be working good.
please say you mixed up your amounts ? 80% coolant isnt gonna cool very well , water is alot better at pulling the heat out than coolant
60-75% is where id max winter mix , and even then id rather 50/50 or higher water content and water wetter or similar
windshield washer fluid...low freeze point...mostly water...works for me.
Serious?! Doesn't the cleaning agent or solvents cause any problems?
Jbdy04 wrote:windshield washer fluid...low freeze point...mostly water...works for me.
Interesting.
We had a 50/50 premix jug of antifreeze sitting in the garage, so i just used that.
i'm planning on 50/50 with a bottle of water wetter for good measure.
also noticed that it dropped my operating temp when i threw it in the rad.
ive tried just dexcool as the factory has, dexcool with redline water wetter, straight distilled water with redline water wetter
not a bit of difference between any of them, i thought running straight water would be my salvation at the bash last year, didnt do a damn thing for me
