when installing the msd fuel pump should i disconet the oem pump or keep both running??????
use both. the msd inline is a helper pump.
should have just went with the racetronix and still been on one pump.
and whats the racetronix part number?????? i bought my injectors there 72lbs
I should probably invest in this as well, so you would need the pump and the harness.
Matthew Jollymore wrote:I should probably invest in this as well, so you would need the pump and the harness.
most definitely and correct.
I purchased the inline MSD never even unboxed it because I saw the Racetronix. What a sweet unit. Installs easy and you dont have that damn whine noise that MSD has.
that part is for our cars? and we can order it from that site? also were there any glitches in your install or did everything just work?
Kick azz is my boost hero!!! "
Jcavi wrote:that part is for our cars? and we can order it from that site? also were there any glitches in your install or did everything just work?
Yea order exactly what you see in that link. Get the harness as well if you want to take full advantage of the kit. I haven't seen or heard of any glitches yet. These pumps are for platic tanks only, but guys have installed them in their metal tanks with I think no issues. Nobody knows why they recommend plastic tanks only.
2012 numbers - 4SPD
AUTOMATIC!!
yep, thats the part you need. buy the full kit and you wont regret it. and follow the install guides on the org and you will be fine. no glitches at all with mine.
