boost then at 3k nothing - Boost Forum
Sunday, September 13, 2009 12:18 AM
finished the turbo kit last night...car runs very strong up to 3k and then has no power...it sputters and maybe misfire...if i stay out of boost it passes 3k fine with no problems...what would cause this...i looked around on the boost forum and say no evidene of others having this problem...
Re: boost then at 3k nothing
Sunday, September 13, 2009 5:27 AM
I had a similar problem when i first installed my turbo, are u running a wideband? U could be running extremely rich if u are not tuned yet and installed larger injectors, also if it is untuned it could be ur timing. U will also want to get some colder spark plugs, im running ngk tr6's from my experience so far they run the best once the car is turboed. They are also cheap, the part number is 4177 they are heat range 6. When i would step on the gas the car would feel like the engine was just cutting out, but my afr would drop down to like 9.0 which is extremely rich, the car wont even move with that much fuel in the lower rpms.
if it can't win a race it better win a show
Sunday, September 13, 2009 6:02 AM
Need more info on your set-up. It can be sooo many times. How is the car being tuned?
Sunday, September 13, 2009 8:12 AM
Magic 8 Ball says: Fill out your registry with the proper mods. After that, please give more information, such as: engine code, tuning software or method, plugs being used, plug gap, fuel pressure, fuel pump, injector size, is there a wideband?, if not, why the hell are you driving a boosted car without one? , what size turbo, what are the specs, are you serious enthusiest or are you just jumping on the bandwagon and the only reason you put a turbo on for is the "uber cool" sounds? Answer these, and then and only then, we MAY be able to help you....
P&P Tuning
420.5whp / 359.8wtq
Sunday, September 13, 2009 12:45 PM
the car is stock other than the turbo...my set up is t3/t4 ar50 turbo 2.5in exhaust to duals god speed intercooler and 2.5in intercooler piping...idk what bov but i have it as close to the tb as possible...i do not have a wide band...i looked on here a long time ago and there were alot of peps running stock motors with boost..so i didnt upgrade anything because i only want 5psi peak...ill get some picks uploaded asap...so no tune no wideband no afpr just stock with boost...
Sunday, September 13, 2009 1:17 PM
ERic Kenney wrote:so i didnt upgrade anything because i only want 5psi peak...ill get some picks uploaded asap...so no tune no wideband no afpr just stock with boost...
That is your problem. You are on stock injectors with no way to increase fuel when in boost. You are probably starting to hit boost at 3k and no fuel. You need tuning.
Sunday, September 13, 2009 1:22 PM
for plugs i got rs9yc and go to this link its my cardomain...for some reason it wouldnt let me uplaod them on here...they are on the last page...not real great but thats all i have
cavalier turbo pics cardomain
Sunday, September 13, 2009 3:48 PM
Ouch! Side feed injectors FTL!
P&P Tuning
420.5whp / 359.8wtq
Sunday, September 13, 2009 3:51 PM
ImPhat0260/Cavattack2000 wrote:Ouch! Side feed injectors FTL!
what is wrong with that?
Sunday, September 13, 2009 4:47 PM
i dont know what others said but check you fuel.
"Kick azz is my boost hero!!! "
Sunday, September 13, 2009 4:56 PM
You can't just upgrade them like top feed. You should really look into a top feed conversion or getting an extra injector controller....
Do a Search on here and you should come up with some ideas/results.
P&P Tuning
420.5whp / 359.8wtq
Side feed injectors can not be upgraded. Still you have to have a way to increase fuel under boost. Tuned with HPTuners, or a FMU (which is a bandaid).
Sunday, September 13, 2009 6:05 PM
John Higgins wrote:Side feed injectors can not be upgraded. Still you have to have a way to increase fuel under boost. Tuned with HPTuners, or a FMU (which is a bandaid).
what is fmu?
I live in panama city florida...where could i go for hpt?
Sunday, September 13, 2009 6:23 PM
what is fmu?
I live in Jacksonville Fl and tune with HPT, but you need to look into doing a top feed injectors swap. Stock injectors are too small.
Sunday, September 13, 2009 8:08 PM
even with 5psi peak i wont be able to use the stock injectors?
Sunday, September 13, 2009 10:33 PM
do you have anything that prevents the MAP sensor from seeing boost? If that thing sees that the system is getting pressurized it freaks out the computer. Try using a check valve so it only reads vacuum.
Monday, September 14, 2009 12:02 AM
Nothing is going to fix itself unless you get that puppy tuned...lol as for the side mount injectors im clueless, but no tune = not enough fuel= misfires, and thing start breaking so be careful.. Look into hp tuners its a pretty sweet lil program i got it on my 2.2 eco, and its really amazing... FMU has to do with fuel management, not sure but i dont think you really need to run that if all your gonna push is 5 psi... With hp tuners you will be able to change your injector constant and tune the car to give fuel in boost, so maybe your stock injectors will work...Good luck!
SuNnY-T
Monday, September 14, 2009 6:27 AM
ok so one more thing before i get some hpt...i have an automatic tranny could this be part of the problem?someone told me that depending on how its made ithe tranny sends signals that vary of vac. and there is no vac. i looked and didnt see anything that jumped out at me...but i am just wondering
Monday, September 14, 2009 6:36 AM
nick bucci wrote: With hp tuners you will be able to change your injector constant and tune the car to give fuel in boost, so maybe your stock injectors will work...Good luck!
You have no clue what you are talking about.... Read my previous post about the top feed conversion.
P&P Tuning
420.5whp / 359.8wtq
Monday, September 14, 2009 8:28 AM
You guys need to stop giving advice when you clearly don't know what you're talking about.
Listen to Ryan, that car needs bigger injectors. The reason you "hit a wall" is because the car goes INSTANTLY lean and falls flat on its face, you are risking detonation and heavy damage like this.
That engine ***NEEDS*** bigger injectors, but because it has side-feed injectors there is zero option to upgrade them. You can either convert to a top-feed setup (lots of work, requires decent tooling/knowledge), or you can run an extra injector controller with a 5th injector (risk of fuel puddling).
There is NO reason to tune the car *yet* with HPT because you do not have enough fuel to tune with, your stock injectors are almost maxed out with stock power, but they are irreplacable. Once you have a way to add fuel, then you can worry about tuning. (And the car WILL need tuning.)
Ryan, I don't understand how you keep dealing with this kind of stupidity.
-Chris-
-Sweetness-
-Turbocharged-
Monday, September 14, 2009 8:36 AM
Agreed
Monday, September 14, 2009 10:37 AM
ok ill look into a top feed conversion...thanks
