tuning ld9 for turbo(question) - Boost Forum
Saturday, September 12, 2009 12:45 PM
do i need to get GM sc reflash or can i just get a HP Tuner(pro)? if so where can i get a GM reflash?
Re: tuning ld9 for turbo(question)
Saturday, September 12, 2009 12:53 PM
You need a 2-bar OS. Get the GM Reflash and then adjust the data as needed. The stock tune does not have accomodations for boost pressure.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Saturday, September 12, 2009 6:19 PM
To answer your question. You do not have to have the GM reflash. Your profile shows your car is a 99 which can take the reflash but you will loose gauge functions on the cluster.
Saturday, September 12, 2009 6:31 PM
To answer your question more thoroughly, you need the GM reflash if you want the car to have the best tuning capability and not use a faked 2-bar setup. I do not suggest running the stock tune and faking the values to run boost. I like my new OS.
650 whp / 543 ft-lb
@turboalero
Sunday, September 13, 2009 6:09 AM
You can also run a 97 Speed Density file which reads map for fueling, this would allow you to still have your gauge functions as well.
Fact is everyone has there own method and what they like for certain years.
Sunday, September 13, 2009 6:48 AM
Sweet I didn't know that, that makes more sense now.
650 whp / 543 ft-lb
@turboalero
Sunday, September 13, 2009 7:14 AM
John, has anyone successfully tuned for boost with that file? I have an 01 so I'll just use the GM reflash to tune mine but my friend has a 96 we swapped to 97 so this would be helpful in tuning his car this winter. I'm in no way doubting just looking for info.
Sunday, September 13, 2009 8:04 AM
[ion wrote: C2]To answer your question more thoroughly, you need the GM reflash if you want the car to have the best tuning capability and not use a faked 2-bar setup. I do not suggest running the stock tune and faking the values to run boost. I like my new OS.
Why does everybody always jump to the fake 2 bar thing? John is right. IT can be done on the stock OS with proper adjustments. Is it the best, NO. Will it work better than a fake 2bar, YES! Hell, its the only thing the ECO guys can do (besides the SC reflash that they can't modify). If you don't care about the gauge functions, then run the SC Reflash.
P&P Tuning
420.5whp / 359.8wtq
Sunday, September 13, 2009 8:16 AM
To the OP I am running a 99 harness with a 2000 PCM with the GM S/C reflash on it. I don't have the stock water temp or tach working. I have aftermarket ones. Out of all my switch a roos with PCM's we found this to be the easiest to tune with.
Sunday, September 13, 2009 11:36 AM
dcampbellz24 wrote:John, has anyone successfully tuned for boost with that file? I have an 01 so I'll just use the GM reflash to tune mine but my friend has a 96 we swapped to 97 so this would be helpful in tuning his car this winter. I'm in no way doubting just looking for info.
I have tuned 2 cars now with the 97 Speed Density file.
If the car is a supercharged car then I would run factory ECU (TPS x RPM) for tuning. If it is Turbo then I would consider switching to one of the 2 option to have it KPA x RPM).
Monday, September 14, 2009 7:33 AM
THe car is turbo'd and is a 5 speed. If anyone has a the stock file for a 97 speed density 5 speed would it be possible to get a copy? I checked the repository and didn't see one. /thread jack
Monday, September 14, 2009 8:33 PM
Dan I have pretty much all your HPTuners needs man... who has the turboed Cavy? I haven't seen it around this area.
President/Founder - 607 Motorsports
Tuesday, September 15, 2009 11:08 AM
Also note lack of "IPW vs VAC multiplier" table for 97 speed density - as noted by Chris (SWEETNESS GT). The 00 does include that table.
http://www.j-body.org/forums/read.php?f=64&i=12216&t=9041&p=5
Mike
Sunday, September 20, 2009 9:41 AM
this is the hp tuner i found http://www.hptuners.com/products/vcmsuite.php has anyone tried it??
and a link to the car it can be used on http://www.hptuners.com/products/vcmsuite_vehicles.php
ps i want to keep the stock gauge functions
Sunday, September 20, 2009 2:47 PM
yes that is the one we all have. you can keep the stock gauge functions. just gota get the fuel maps propper. listen to john he helped me tune my Z did not run a fake 2 bar and it ran great. if i can find my file i can send it over to you to use as a base.
PJ
Tuesday, September 22, 2009 2:04 PM
cool ok thanks
