Just installed brand new Ford Green top 440 injectors on my 99 2.4. Seems that the first two injectors are leaking, checked the o rings seem to be in great condition. Anyone else have this type of problem, or any ideas what could be causing it? thanks guys.
Where exactly is the leak coming from? Orings may be rolled or sliced and you are not seeing it.....
P&P Tuning
420.5whp / 359.8wtq
it appears the leak is coming up from the sides of the injectors after inserting them into the engine
hey whats up jersey cavy, i remember seeing ur car at the merchantville car show like 2 or 3 years ago, i just recognized it from the pic
if it can't win a race it better win a show
Do any mods to the fuel rail have to be done with using the Ford 440 injectors? Maybe their not sitting right?
try using your stock inj o-rings , and lube them before slipping them into the rail and the head , also make sure and use the clips that hold the injectors to the rail
Sounds like a plan, will try it out tomorow, thanks for the help
