Use A/C condenser as air/water IC exchanger? - Boost Forum
Wednesday, August 19, 2009 1:20 PM
I'm considering ditching my A/C system for the weight savings, and also I was thinking I might be able to use the condenser as a heat exchanger for my air to water intercooler. I'm trying to keep the car stock looking, which is the reason I went with an air/water unit rather than a FMIC. Will the condenser flow a decent amount of water or is it too restrictive?
2002 Cavalier 2200 5spd
Re: Use A/C condenser as air/water IC exchanger?
Wednesday, August 19, 2009 1:45 PM
could work, b ut the condensor is made for keeping highly pressurized air going thru it, not water, but who knows the chinabay h/e uses a air/air core and it works fine for water/air set ups, so u may be able to pull it off...
