How can I adjust my internal wastegate arm? - Boost Forum
Tuesday, July 14, 2009 3:10 PM
Should I lengthen or shorten the arm for less or minimum boost. I have a boost controller now so im looking to put the wastegate on its lowest setting then use the boost controller to run the show
Re: How can I adjust my internal wastegate arm?
Tuesday, July 14, 2009 3:14 PM
make it longer, longer=opens faster, shorter means more tension which opens later
be careful though dont open to to the pojnt were it wont seal against the flapper hole, it should only open as much as i can whie still sealer against the hole
Thursday, July 16, 2009 9:21 AM
longer means less boost shorter means more boost
horsepower is how hard you hit the wall, Torque is how far you push the wall with you
Thursday, July 16, 2009 1:08 PM
i extended my rod, all is good
Thursday, July 16, 2009 1:17 PM
nice man...how much boost u pushing now vs before?
Friday, July 17, 2009 6:59 AM
Rodimus Prime wrote:i extended my rod, all is good
umm yeah...
you were just waiting for somebody to comment.
So here I am.
Your welcome
