Tune for <6psi? fuel injectors? - Boost Forum
Friday, July 10, 2009 5:03 AM
Ok so I read the faqs. Thinking bout making a turbo setup for my 02 2.4. So I dont need fuel injectors or pump if I plan on running less then 6psi? What do I need to do for tuning purposes? It does not say much in faqs about tuning. I know I will need a fmu. Thanks guys for your help.
02 Cavalier Z24- Free CAI I made, magnaflow muffler
02 Trans am ws6 - Pace setter long tube headers, off road y-pipe,magnaflow exhaust, slp lid, bored polished throttle body, throttle body by pass, some other free mods, jegster lower control arms. best ET 12.7@112mph Heads/Cam in future
Re: Tune for <6psi? fuel injectors?
Friday, July 10, 2009 5:24 AM
You need larger fuel injectors for any boost level....
And HPTuners, no need for a fuel management unit.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Friday, July 10, 2009 2:11 PM
Ok so what injectors are ideal? And I dont need a FMU? Just have someone tune it with hp tuners? Thanks man. Also so the stock fuel pump will work ok?
Friday, July 10, 2009 5:12 PM
I would get at least some green tops. YOu can have someone put the GM reflash on your car and then add the 2 bar map sensor. They would then be able to do some good tuning.
Friday, July 10, 2009 8:35 PM
Cobalt SS/SC 36lb injectors, you can get a set of 4 for only $30-50. As said someone reflashes your car with the supercharger kit reflash, you use the 2 bar MAP sensor, and then adjust the fuel injector constant and all the fueling/spark tables to your liking.
650 whp / 543 ft-lb
@turboalero
Friday, July 10, 2009 9:10 PM
where do u get these injectors for so cheaaaaaaaaap ive been looking for some and cant find any for that price?
would saturn ion redline injectors work the same?
Friday, July 10, 2009 9:23 PM
Wait I thought the GM Reflash locked the ECU
Friday, July 10, 2009 11:24 PM
Zach Reliford wrote:Wait I thought the GM Reflash locked the ECU
For the Ecotec yes. For the 2.4 no.
Saturday, July 11, 2009 4:14 AM
[ion wrote: C2]Cobalt SS/SC 36lb injectors, you can get a set of 4 for only $30-50. As said someone reflashes your car with the supercharger kit reflash, you use the 2 bar MAP sensor, and then adjust the fuel injector constant and all the fueling/spark tables to your liking.
Took the words outta my mouth. I vote to run 440cc/min injectors (ford green tops) because if/when you get it all installed/tuned, you will want more
Saturday, July 11, 2009 9:19 AM
what car do the green tops come on?
Saturday, July 11, 2009 9:50 AM
True green tops are Ford injectors. I believe the Cobra and the lighting. Cobaltss/sc injectors are green in color, but slightly smaller and cheap.
Sunday, July 12, 2009 3:04 PM
The 2 bar is not required is it? What would be the easiest way to tune it for less then 6psi? My buddy has HP I think he would be able to help me out but he is used to tuning lsX motors. And where can I find these Colbalt SS injectors? Thanks fellas!!
Monday, July 13, 2009 10:18 PM
A local guy and myself each scored low mileage sets of lsj (cobalt ss/sc) injectors for under $30 shipped. Go check out cobaltss.net and do some searching.
Thomas
