hey guys i just put my supercharger on last week and its awesome had a problem with bypass vavle but all fixed.i was just wonder if i would be running lean or not. i am running a m62 charger with the 2.2 ecotec with the gm reflash and i have the gm stage 2 kit which is 3.0 pulley, stage 2 belt and 42lb injectors. im not running the 42lb, im running the 36lb. so am i running lean or not. thanks alot guys
What does your wideband say?
Tinkles
2003 Cavalier 1SV
Bagged and Blown
dont have one just asking if anyone knew because i ordered one and i drive my car daily. i dont want it to blow up
All I can tell you is the GM reflash runs pig rich with the stock pulley and injectors. You are taking a risk by making the pulley smaller and not using a wideband without tuning
At high rpm it is more than likely leaning out to about 13-1. That's what mine did on the 3" pulley
(Tom) S/C Fire wrote:At high rpm it is more than likely leaning out to about 13-1. That's what mine did on the 3" pulley
mine was the same
12.33 @ 111.67 mph [Oct 2009]
327.6 WHP 333.6 WTQ [10.1 AFR]
Drive it normal until you get the wideband. Why didn't you use the 42lb injectors?
im running the gm reflash i need to get a tune. also if i put the 42lb injectors will my engine hold up?
will the reflash control the thde 42# injectors
Built&Boosted moar
no i need a tune to run the 42lb injectors
