I was wondering about picking up a M45 from someone on the cheap
How hard and how expensive would the remaining parts be to come by?
I have HPT so i can do the flash
I have a set of the 310CC injectors from the kit already
I would need the Brackets and Idler Pulley aswell as any other parts not easily purchased
Also would need a 2 Bar MAP
Anyone have any spare M45 kit parts laying around?
Bolts and Nuts arent an issue
Edited 2 time(s). Last edited Monday, June 15, 2009 11:57 PM
Good luck. Your more than likely going to have to buy a used kit from someone.
I got a 2bar MAP for sale. Plugs right in.
Ill let you know about the MAP
One part already
The belt is a non issue but items such as the PCV baffle, idler pulley, and brackets are going to cost you an arm and a leg. Do you have the part numbers of all the items you need? If so check gmpartsdirect just beware they effing rape with no lube on the shipping price! Even then consider yourself lucky if you can even get the parts.
My kit was missing the PCV baffle and idler pulley and I bought those items through gmpartsdirect and it was around 500 bucks shipped for the two. That was also 2 yrs ago.
Edited 1 time(s). Last edited Tuesday, June 16, 2009 12:53 PM
![](http://i37.photobucket.com/albums/e69/wjz24/notforsalesig.jpg)
