so, i did some searching and i didnt find what i was looking for. i did find the the ss injectors are 36# injectors. My question is how much boost can these support? Does it depend on the turbo i get? let me know and sry if i didnt search enough or in the right place.
horsepower is the force that determines at what speed you hit the wall, torque is the force that determines how far you take the wall with you after you hit it.
02 silver cavy wrote:so, i did some searching and i didnt find what i was looking for. i did find the the ss injectors are 36# injectors. My question is how much boost can these support? Does it depend on the turbo i get? let me know and sry if i didnt search enough or in the right place.
Depends on turbo size like you said, they seem to work well with th SAAB setup. If you have something bigger you will want larger injectors. I think the Ford Green Tops are a great option, cheap if you find a used set and gives you a little bit of headroom.
![](http://www.ohiojbody.com/misc/jbosig.jpg)
Hahn Stage II - Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
Every set-up is different. Probaly get 8-10 psi.
and the ford green tops just fit right in correct? i know i need the connector but there the right size? whats the pound rating on the green tops?
