evilmonkitar wrote:mine has a spring in it for the boost level, maybe yours broke? i dont think they are too much, try a new one (switch) and hopefully that fixes it
Jake wrote:figure it out?
i had the coolingmist kit and didnt have a issue.
good luck
BlownBlackZ wrote:John Higgins wrote:I now have a LED that comes on when the boost switch kicks on.
I did this as well, with the LED installed in the pod right beside the boost gauge. Could possibly be a problem with the relay itself, you never know.
John Higgins wrote:Yes thought of that too. Question where did you hook the LED up to? I did it per coolingmist directions. It gets it signal to come on from the boost switch. Did you do the same?
z yaaaa wrote:damn- thats a very sweet idea to put an led in the cabin so you know EXACTLY when its activated. i really like that...
im gonna have to do that with my juice...
Matthew Jollymore wrote:this is a little off topic but since this is the most recent discussion on meth I thought I'd just shoot a question. I have the cooling mist kit and have it set to come on somewhere around 3.5-4psi. So as soon as I hop on the throttle it sees at least 5 psi and starts spraying. On the dyno we noticed that the green light in my guage pod shuts of when at WOT on the dyno from about 4300 to 4600 rpm...not sure what would be causing that. The boost wasn't falling below the 4 psi so I am wondering if it is another issue. Sees between 5-7psi depending on rpm of engine. Any help would be appreciated.
John Higgins wrote:Well went to go to the dyno today (local shop doing a dyno day). On my way LED light up and stayed on. Turned system off, then back on still on. I did not dyno because of this. After leaving the shop LED turned off. So far not come back on. Still going to check a few things but seems my boost switch is bad. I will be ordering a new one from cooling mist.
I was against the LED in the cabin, but now see it's purpose.
. wrote:John Higgins wrote:Well went to go to the dyno today (local shop doing a dyno day). On my way LED light up and stayed on. Turned system off, then back on still on. I did not dyno because of this. After leaving the shop LED turned off. So far not come back on. Still going to check a few things but seems my boost switch is bad. I will be ordering a new one from cooling mist.
last week at the track I told you I had a switch and a led we could put in . BUT NOOOOOOOO![]()
John Higgins wrote:. wrote:John Higgins wrote:Well went to go to the dyno today (local shop doing a dyno day). On my way LED light up and stayed on. Turned system off, then back on still on. I did not dyno because of this. After leaving the shop LED turned off. So far not come back on. Still going to check a few things but seems my boost switch is bad. I will be ordering a new one from cooling mist.
I also had one as well. That is what I installed.
. wrote:John Higgins wrote:. wrote:John Higgins wrote:Well went to go to the dyno today (local shop doing a dyno day). On my way LED light up and stayed on. Turned system off, then back on still on. I did not dyno because of this. After leaving the shop LED turned off. So far not come back on. Still going to check a few things but seems my boost switch is bad. I will be ordering a new one from cooling mist.
If you have a switch then why are you going to have to order one from cooling mist ???
like i said I have a switch ..... but thats cool
