will a 97 2.2 block work in my 98 2.2 car - Boost Forum
Wednesday, January 14, 2009 3:46 PM
befor i spend money on getting the block work done i need to know if it works or not
Re: will a 97 2.2 block work in my 98 2.2 car
Wednesday, January 14, 2009 5:11 PM
no 2.2 is 97 and 2200 is 98
Thursday, January 15, 2009 2:27 AM
It would work, if you change the crank and pistons. By the time you do that, you can just go and get another '98+ block (if your staying with a stock bottom end).
Thursday, January 15, 2009 6:41 AM
im planning on having a fully built forged bottom end. plus i already have the 97 block from my 97 rs i totaled last year
Thursday, January 15, 2009 6:59 AM
well the crank is even the same i used a 97 2.2 block in my 98 2200 car because i couldnt find one around me i just changed the pistons and head and called it good it was just a daily driver but i didnt have any problems
my kill list:a geo metro and a mac semi wow did i kill that thing
Thursday, January 15, 2009 9:21 AM
definitely have to use the 2200 pistons and head, but the block should be the same.
GL getting a forged crank BTW, forged rods are always good though.
Thursday, January 15, 2009 9:40 AM
Home jBP Team 2nd Gen Products 3rd Gen Products Cobalt/Redline/HHR/G5 Solstice/Sky Customer Cars Contact us
Part Details JP0412
JP0412 - JBP 4340 Forged Steel 84mm Crankshaft
Price: [$1320 (US$1108.80)]
Finally, a crankshaft available for serious modifications. Our forged crankshaft is absolutely revolutionary. The first thing that comes to mind with forged cranks are the ability to withstand large amounts of power, (before they exceed their yield stress). Our crank is the not only forged steel. But also fully customizable. Journal diameters have been made in such a way that you can offset grind the crank to gain a larger stroke. (Additional Fee) Our forged crank also has a customizable crankshaft position sensor timing ring. With this we have the ability to advance your timing right off the crankshaft. You tell us that you want to advance the timing 2degrees, consider it done. Our forged crankshaft is made from 4340 forged steel and is knife edged. So for those worrying about bottom end stability, worry no more. With the customizable nature of our forged crankshaft and all the options available for aftermarket rods, jbody enthusiasts now have that performance edge that only JBP can provide.
Buy Now
jBody Performance Inc. © 2000-2008
Thursday, January 15, 2009 10:02 AM
ill pass
Thursday, January 15, 2009 11:29 AM
should i get this crank or should i stick with my stock crankthen im new to building motors i just figured since it was forged it would hold up to what my plans for the car
Thursday, January 15, 2009 11:51 AM
larry stutler wrote:Home jBP Team 2nd Gen Products 3rd Gen Products Cobalt/Redline/HHR/G5 Solstice/Sky Customer Cars Contact us
Part Details JP0412
Buy Now
I don't see anywhere where it says this crank is for the 2.2 or the 2200. Sounds like a total waste of money anyhow.
Friday, January 16, 2009 2:48 AM
The crank position sensor notch are in different positions on the two cranks.
Rebuilding the Chevy 2.2L Engine, Doug Anderson, Automotive Rebuilder, July 2000 wrote:CRANKS
There have only been two crank castings used in the 2.2L engines, but one of them comes in two flavors, so it must be visually identified.
1990-‘95: These engines all used the 1237 casting.
1996-‘97: These engines came with the 4618 casting that is virtually identical to the earlier 1237. They are both interchangeable.
1998-'99: These engines still used the 4618 casting, but the timing notches were advanced by about 0.450", so the later crank can’t be interchanged with either of the earlier ones.
It’s easy to tell the difference between the two 4618 cranks when you see them side by side
With both cranks facing you and the keyways at 12 o’clock, note the location of the notch at the top of each reluctor wheel. If the right edge of the notch is about .500" to the left of the casting seam and located around 11 o’clock, it’s the early, retarded crank.
If the right edge of the notch is right next to the casting seam and nearly straight up at 12 o’clock, it’s the later, advanced crank that came out in 1998. Don’t mix them up, or you will have a comeback.
That article can be found here.
