Ok I was wondering that if I install the gm supercharger for a 98 z24 ( ld9) how long would it take to install it? because I was thinking of doing it myself and wanted to know
mine took about 8 hours at a local shop...had a feller put it in, he never installed anything like it before but he has a racing background so managed quite well. But when he installed it he took a peak to see what people were charging for install time and it was ranged from 7-10 hrs.
You should be able to get it in about 8 hours maybe less your first time. The part that took me the longest was getting that mother @!#$ POS brake booster vaccum tube line out of the way. It is bolted to the block and the sharp square tab welded to the tube seemed to get caught on every single @!#$ wire on the way out. You will have to wiggle and twist and wiggle and twist it some more to get it out.
I know this is off topic...but wade I can't believe your selling your car, its awsome! Where the s/c bracket screws into where the factory intake was it had corroded and took him an hour to clean it out to get the s/c bracket bolt down though.
isnt too bad of a install
make sure you zip tie your coolant lines far away from your belt.
and what you using to delete your EGR? (hp tuners)
Wow 8 hours?! Only took me 3 1/2 and i had never even seen the install instructions.
I cant say how long it took me. I was installing my new motor at the same time lol.
ecotecpower wrote:Wow 8 hours?! Only took me 3 1/2 and i had never even seen the install instructions.
lmao everything's easier on the ecotec.
And I should've been drown in the rivers I've found in token lost...
took me and my dad only 4 hours to do the install. It's super easy.
z yaaaa wrote:ecotecpower wrote:Wow 8 hours?! Only took me 3 1/2 and i had never even seen the install instructions.
How do you figure that?? This thread is about the ld9, which is what I was talking about. The LD9 kit took me 3 1/2. My ecotec took 8
