Does anyone know how to remove the hub off the supercharger snout from my mp45? i need to take the hub off and put the stock one back on. Thanks.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Very carefully? Ha
I would assume it's similar to the process of removing a stock one. You may be able to make good use of the 5 holes around the hub itself, fab up some sort of puller-type device.
14.330 @ 96.37mph
thanks but im sure theres a way to get it off without having to fab something up. like a tool or something....
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
Smoothflow has a pulley remover you can use
Try a power steering pulley remover. Applying heat will help also.
Use a power steering remover, i did and didn't need any heat or anything. Came right off.
you removed your Smoothflow aluminum HUB with the power steering puller, eh?
2001 Olds Alero (LD9)
636 whp / 543 ft-lb
@turboalero
yeah i need to get the hub off, and put the stock pulley on. not the other way around. i dont wanna damage anything.
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
The easy way?
Take the snout off, and use a Press.
Chris
'02 Z-24 Supercharged
I'm gonna be a vulture here. What are you going to do with the hub and pulley? I am in need of that system. If you don't damage them getting it apart I may be willing to buy. PM me if you want.
Labrat
lol nah man, its not for sale. i need to put the stocker back on to send it back under warranty. the snout is leaking and my parts hookup is getting it warrantied. im getting a new charger....
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
No prob man. I will find them somewhere. It's just I have dropped quite a bit lately on the ride and the wife ain't gonna be happy with me spending 300 on a pulley. Dam women. Hope you are all fixed and running soon.
Labrat
dude i paid 100 bucks for my pulley and hub. check out smoothflow pulleys
01' Z24 5 speed
422whp/400wtq
T4 Turbocharged
Built LD9
HP Tuners
