Help 3.0 pulley belt? - Boost Forum
Monday, November 03, 2008 4:33 PM
I put the 3.0 pulley on and looked at the belt that zzp sent me and it is 6 rib which doesn't match with a/c crank etc....what did you guys do to get this to work?
Re: Help 3.0 pulley belt?
Monday, November 03, 2008 4:35 PM
cut one rib off the belt. It doesnt look like it will do the job but when you cut that one rib off it will fit.
Monday, November 03, 2008 4:38 PM
Does the zzp adjustable tension work on our cars?
Monday, November 03, 2008 4:39 PM
Not sure, I just use the cobalt tensioner.
Monday, November 03, 2008 4:47 PM
is that what came with the gm kit?
Monday, November 03, 2008 4:52 PM
Yeah. Best way to get a hold on that thing is with a pair of vice grips. They will make your day alot better!
Monday, November 03, 2008 4:55 PM
do you just pull it up b/c it looks like a shock
Monday, November 03, 2008 5:13 PM
no, clamp it to the black square part of the tensioner, right at the top, and push it towards the rear of the car.
Monday, November 03, 2008 5:24 PM
that would cause the shock thing to reduce in size if I could even get it to move at all.
Monday, November 03, 2008 6:03 PM
yeah thats what you want so you can put the belt on
Monday, November 03, 2008 6:21 PM
how do you tighten it?
Monday, November 03, 2008 6:45 PM
Lol, Let go of it. I must not be understanding what it is you are asking.
Monday, November 03, 2008 7:11 PM
I am not very smart so it could be a combination. I don't understand how it can loosen or tighten since the thing doesn't budge unless you unscrew it.
Monday, November 03, 2008 7:19 PM
Its like a shock. It moves up and down under different throttle. You'll need to pry it down.
Monday, November 03, 2008 7:23 PM
so it will self tighten? any other options beside trim the 6 rib belt to a 5 rib?
Monday, November 03, 2008 7:35 PM
Yeah its self tensioning. Dont really see any other way than trimming the belt
Monday, November 03, 2008 7:40 PM
there is a nub on the tensioner...
I have uber long wrenches, I fouind one that fit, and push like hell twards the firewall... it will releave tension, till you let go...
** FOR SALE** http://www.j-body.org/forums/read.php?f=24&i=110879&t=110879
Tuesday, November 04, 2008 3:39 AM
I was hoping not to trim the belt but if that is what must be done that is what must be done.
Tuesday, November 04, 2008 4:26 AM
sorry to hijack but if you go down to a 3" pulley, do you have to use a smaller belt or can you use the one that came with the s/c kit?
M62 KIT for sale PM ME
Tuesday, November 04, 2008 4:50 AM
that's a good question b/c that would make things easier
Tuesday, November 04, 2008 7:04 AM
Also those of you who have cut the belt have had no issues with the belt? did you get the tensioner from zzp?
Tuesday, November 04, 2008 7:57 AM
did a quick search.
http://www.j-body.org/forums/read.php?f=40&i=137168&t=137092#137168
belt is fine from what i read in that post
Tuesday, November 04, 2008 10:03 AM
That helps a lot thanks.
Tuesday, November 04, 2008 10:29 AM
no prob. i was curious about this as well cause im going to be getting a 3" pulley from my buddy who has a ss/sc cause hes going to a 2.9 pulley.
Tuesday, November 04, 2008 1:05 PM
I cut my belt about 5000 miles ago to go to the stage 2 GM belt. I have had no issues, but I am not running the zzp tensioner.
