TB Spacer for Alky Injection - Boost Forum
Saturday, April 05, 2008 2:26 PM
Quick question about this,
It appears as though im better off running my alky injection kit to a TB spacer and taping that, it also appears as though people are using the OBX TB Spacer which many find on Ebay for quite cheap.
Just a precautionairy question here, I found this ( http://cgi.ebay.ca/OBX-Throttle-Body-Spacer-96-01-Pontiac-Sunfire-2-4L_W0QQitemZ370038354391QQihZ024QQcategoryZ33558QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting) on ebay, and am wondering if this is the right thing to use and if its the most widely used TB Spacer for our cars. If not, id appreciate it if anyone would guide me in the right direction.
Also, I have a 62mm TB, anyone know if this TB spacer will work against that, if the opening is only 56mm for instance, then my 62mm TB will become more or less useless, and if it is smaller than my TB, can I make it bigger, like grind or mill it to be bigger?
Thanks
______________________________________
2002 Pontiac Sunfire GT - Supercharged
Re: TB Spacer for Alky Injection
Saturday, April 05, 2008 2:43 PM
I was thinking about doing this as well, not sure what the tb spacer size is but Im sure any one for the 2.4 would work fine. Ill wait for BOOSTED to chime in
Saturday, April 05, 2008 5:23 PM
well, i JUST did mine with the obx r spacer off ebay for $40 and it works well with the 62mm, about the same diameter, it's not smaller i can tell you that much. If you need any help give me a PM beings that i know exactly how to setup meth injection in a spacer now because i just did it.
Saturday, April 05, 2008 9:40 PM
perfect, ill buy that spacer and ill be in touch with a PM when it comes time to install my kit.
thanks very much
