Can i use a stock SRT4 turbo for my turbo setup?
No, the turbo and exhaust manifold are one piece. You'd have to cut it and have it welded to an ecotec turbo manifold.
Check out the Solstice GXP or Saturn Sky Turbos.
Youve gone and done contradicted yourself Admiral! LOL
I have one sitting in my garage. Number one, if you look at the way its setup. Its actually setup for reverse flow anyway and would not really work well for any engine other then the one it was adapted to (@!#$ dodge...)
The manifold is very inefficiently set up and the internal gate does not help at all either.
In terms of turbo design. It sucks. Not worth it at all to do the work to get it to fit and work well. You might as well go aftermarket. Its Very small anyway.
Yeah, I kinda did lol.
Let me try this again: If you're going to use it, it's going to take more work for a turbo size you can find in a lot of places.
the turbo is very small but it's enough to get them into the 13's easily so i say if you have it already go for it, you can always swap turbos.
Alex Richards wrote:Youve gone and done contradicted yourself Admiral! LOL
Aren't
ALL Mitsubishi turbo setups designed to spin "backwards"?
"Youth in Asia"...I don't see anything wrong with that.
I think you might be right but I dunno for sure.
Youd think they would have to go south of the equator before the turbos start spinning backwards...
