LTR6IX-11 Ecotec plugs - Boost Forum
Sunday, November 11, 2007 4:12 PM
I figure this plug is the correct iridium 1 stage colder ngk plug for the ecotec engine.
I plan on getting a set. Who's using these plugs?
Re: LTR6IX-11 Ecotec plugs
Sunday, November 11, 2007 10:35 PM
I did, and then found out they last for like 15k miles then lose their edge.
Look at it this way, those plugs are designed for high power race engines. I even called denso and they suggested replacing them every 10k miles. I'd much rather save a few bucks and get an ac delco copper or iridium plug that lasts 5 times longer
LE61T PTE6262 Powered
Monday, November 12, 2007 8:39 AM
QBE (Aka Phil No More Boost) wrote:I did, and then found out they last for like 15k miles then lose their edge.
Phil what Ac Delco plug would you recommend for a Boost Ecotec?
Monday, November 12, 2007 9:46 AM
ngk makes the plugs for the eco's under the AC delco name , AC delco doesnt make their own plugs any more
the stock replacement plugs i got for the g/fs s/c eco are ngk irridum plugs , they just have the AC logo in them
Monday, November 12, 2007 10:20 AM
[quote=97cavie24ls(™)]ngk makes the plugs for the eco's under the AC delco name , AC delco doesnt make their own plugs any more
Part number for those by chance?
Monday, November 12, 2007 10:39 AM
You can also get an NGK iridium plug from the Dodge dealer which was made for SRT4s and is 2 stages colder than stock eco plugs. They tried to sell them to me last time I went to pick up some copper ones, Im wondering if anyone has tried them, model # LZTR6A-13 I think a set was like 25 bucks.
Mitsu TD06-20g |3" Downpipe w/ Cutout | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
Monday, November 12, 2007 10:59 AM
Yeah i am using the LTR6IX-11 Ecotec plugs and i just got boosted so i dont know how long they last, but they sure work really well
My CarDomain!!! --- http://www.cardomain.com/ride/2543660
Monday, November 12, 2007 11:15 AM
I am using the 1 step colder NGK iridium from the SRT-4. I needed iridiums because the regular plugs kept having spark blow out under boost.
2004 Cavalier coupe, 5 speed, White
GO
Hahn Stage 2, Eagle rods, Wiseco 8.9, SS Valves, Dual valve springs, valve job, Ti seats and retainers
spec stage 3, Fidanza 7.5lb flywheel, Short Shifter
Slotted and dimpled rotors, EBC green stuff
SHOW
VIS EVO CF hood, KOBE KAM 5 17", Nexxen N3000, Ebay Black tails and filler, 5% tint
Gold line springs, Tokiko D-spec struts
ELECTRONICS
Kenwood in-dash DVD and Navigation, single Kicker CompVR
http://www.cardomain.com/ride/2974835
Monday, November 12, 2007 11:20 AM
Darryn DiSanto wrote:I am using the 1 step colder NGK iridium from the SRT-4. I needed iridiums because the regular plugs kept having spark blow out under boost.
What gap were you running?
Monday, November 12, 2007 11:28 AM
I was about 030. I don't have a good gapping tool. The $0.99 one at the register. That was at only 10psi.
GO
SHOW
ELECTRONICS
Monday, November 12, 2007 12:44 PM
John Higgins wrote:[quote=97cavie24ls(™)]ngk makes the plugs for the eco's under the AC delco name , AC delco doesnt make their own plugs any more
no i dont , but they replaced the platinum plugs that AC previously used
Monday, November 12, 2007 12:46 PM
BlackEco wrote:You can also get an NGK iridium plug from the Dodge dealer which was made for SRT4s and is 2 stages colder than stock eco plugs. They tried to sell them to me last time I went to pick up some copper ones, Im wondering if anyone has tried them, model # LZTR6A-13 I think a set was like 25 bucks.
those are the plugs I most recommend for a boosted ecotec, but some people claim they are too long and stick into the cylinder head which I disagree with seeing as I had a spare head and put them in and did not clear any farther then a stock plug.
John: As far as an ac delco plug for a boosted ecotec. I dont know any specific part numbers. I always used the srt-4 ngk copper plug. I have 8 extra sitting herre
Tuesday, November 13, 2007 10:40 PM
So the stock neon Str4 plug is one stage colder than the ecotec?
Our stock plug heat range is 5, the srt's is 5 also but is designed for a turbo engine.
Wednesday, November 14, 2007 2:34 AM
I was always told the NGK Copper Plugs for the SRT4 are 1 range colder. there was a big debate on the ecotec plugs for turbos about a year ago
Wednesday, November 14, 2007 8:11 AM
QBE (Aka Phil No More Boost) wrote:I was always told the NGK Copper Plugs for the SRT4 are 1 range colder. there was a big debate on the ecotec plugs for turbos about a year ago
I was under the impression that the NGK SRT plugs the model number above was 2 stages colder, the SRT plugs that are 1 stage colder are the Champion Copper plugs which are what I'm currently running gapped to 025.
There may also be some NGKs that are 1 stage colder but I think they only show up for the 02 model year in the computers at the dealer.
Wednesday, November 14, 2007 10:00 PM
Well, I just got a set of stock heat range srt iridium plugs. LZTR5AIX-13
We'll see how it goes.
Wednesday, November 21, 2007 7:36 AM
Phil they are longer weather you like it or not or see it or not.
GM Ecotec is 25 mm spark plug and SRT plug is 26 mm.
I PERSONALLY DETONATED ON SRT PLUGS HEAT RANGE WAS TOO HOT AND BROKE RING LANDS HENCE BLOWING THE MOTOR.
I SAY DON'T USE SRT PLUGS, but to each their own.
You guys can also get LTR7IX-11 which are 2 stage colder nad I ran those with 23 psi and 80 shot dry so they are a hell of a plug.
SunCavi
Best time:"""11.946""" @ 114.73 mph @17psi 1.83--60"
11 second daily driver!!!!
Race Related 727-561-9440
Shop of choice for your 11 second J body!
Also, built bottom end and or top end LSJ and L61's available.
13's ----12's ----11's ----10's
Wednesday, November 21, 2007 9:08 AM
Sun Cavi is correct. That would be the best Plug to use if you are going higher than 10psi.
I hope you are all writing that down. LTR7IX-11
GO
SHOW
ELECTRONICS
Wednesday, November 21, 2007 9:12 AM
SunCavi_L61-T4 wrote:Phil they are longer weather you like it or not or see it or not.
SunCavi
I am also living proof of that as well. The Srt4 plugs are horrid. I ran them and they gave me nothing but problems. I am using The Ac Delco Irridiums.
Wednesday, November 21, 2007 9:37 AM
Darryn DiSanto wrote:Sun Cavi is correct. That would be the best Plug to use if you are going higher than 10psi.
Phlatcav gave me that part number about a year ago...been running them sense then...I'd say I like these best myself!
Wednesday, November 21, 2007 10:49 AM
OK WHERE IS A GOOD PLACE TO ORDER THESE?
Wednesday, November 21, 2007 11:50 AM
Got mine from www.sparkplugs.com
Wednesday, November 21, 2007 12:25 PM
http://sparkplugs.com/results_cross.asp?pid=6510&x=49&y=10
I had nothing but good results with mine.
Wednesday, November 21, 2007 12:26 PM
Crap sorry, the ones I had might of been 2 stages colder as I was running 15psi on a 2.9 pulley.
sorry for the miss info.
Wednesday, November 21, 2007 12:59 PM
Phlatcav wrote:http://sparkplugs.com/results_cross.asp?pid=6510&x=49&y=10
Those are two stages colder...that's the plugs I have.
Heat range on stock is 5 and those are 7.
