how would a turbonetics t3.t4 60-1 run with 370cc injectors and gm eco reflash - Boost Forum
Sunday, June 03, 2007 10:35 PM
just like the topic asks, how do you think the 60-1 would run at 7 psi with the gm eco reflash??
Re: how would a turbonetics t3.t4 60-1 run with 370cc injectors and gm eco reflash
Monday, June 04, 2007 11:49 AM
Better question...why would you buy a 60-1 to run 7psi?
fortune cookie say:
Monday, June 04, 2007 2:42 PM
I had the cobalt ss injectors, I believe about 36lb/hr close to 370cc, and 7psi. I was tuned with an FMU though, but it ran super lean. Just my experience. Also have the same turbo, but the only reason I ran such low boost at the time was because it would lean out. Don't have any problems now and I run 12-15psi with 44lb/hr Accel injectors. BTW the old set-up was good for about 200whp at 7psi, but I also had a cracked turbo manifold at the time as well.
Monday, June 04, 2007 5:51 PM
Put it all together and let us know.
14.330 @ 96.37mph
Monday, June 04, 2007 6:22 PM
people have the saab turbo setup with 37 lb/hr injectors with the gm reflash with no problems.
I want to share something with you - the three sentences that will get you through life. Number one, 'cover for me', Number two, 'oh, good idea, boss', Number three, 'it was like that when I got here.'
Monday, June 04, 2007 6:54 PM
i have a tdo4h with 370cc injectors and it runs fine,but i want to step up to the 60-1 now and then drive it for awhile and then tune it with HPT and also while my motor is being fully built. thats y im gonna run 7psi
Monday, June 04, 2007 8:21 PM
umm 7 psi on a 60-1 is no where near its efficiency...
but i have a garret 60-1 that i'm selling.. PM me lol
Monday, June 04, 2007 9:21 PM
your current setup will most likely be faster then if u do the switch to the 60-1. (not effecient with that lil boost)
advice, save the 60-1 till the new motor is built
http://www.myspace.com/15102113
12.5@116 2.0 60ft
Monday, June 04, 2007 9:30 PM
ill just buy it and get everything together for the new build and just sell this current setup once i swap over
