CEL but cant scan! - Boost Forum
CEL but cant scan!
Monday, April 23, 2007 7:08 PM
So after I installed my Hahn stage II kit about 3 weeks ago, my check engine light has been on. Well I tried to scan it the other day
and when we plugged it up nothing would show up. We turned the key forward, plugged in the scanner, but the scanner never came on.
So I tried another scanner and the same thing happened. I need to know what the codes are and also doesn't HPT plug into your
OBDII port also? So I won't be able to get tuned?
Re: CEL but cant scan!
Monday, April 23, 2007 7:19 PM
I have a MAC code reader it will turn on with out the key on. In order to erase codes or check data the key must be in the run position.
Isn't boost fun!!!!!!
Monday, April 23, 2007 7:24 PM
yea the key is turned to the run position....but the scanner just stays blank
yup boost is great
Monday, April 23, 2007 7:27 PM
When you get it working, let me know what codes you have.
What kind of scaner are you using?
Monday, April 23, 2007 7:29 PM
I went to advanced auto and auto zone. They both had different ones
Monday, April 23, 2007 7:42 PM
you have a blown fuse............its either your DLC(data link controller fuse) or its the cigarette lighter fuse.........im pretty sure its the dlc.
it in the panel on the dash....and its labeled DLC
*************Yea i spell liek wrong get over it*****************
** If i write in caps its cause im @ work and i can only write in caps cause the keyboard is a retarded CAPS only keyboard.**
Monday, April 23, 2007 7:43 PM
Those are a joke. I picked up mine for $60 off the MAC Tools truck.
Monday, April 23, 2007 8:37 PM
As snowman said - blown fuse. Replace and it will work.
-Chris-
-Sweetness-
-Turbocharged-
Monday, April 23, 2007 9:01 PM
SweetnessGT wrote:As snowman said - blown fuse. Replace and it will work.
-Chris-
x2
Tuesday, April 24, 2007 6:33 AM
thanks everyone! I'll try that and let everyone know.
Tuesday, April 24, 2007 7:11 AM
it could be more as well if that fuse trick doesnt work check your grounds. I had a loose main ground on my tranny housing and fixing that fixed my obd2 port problem.
Tuesday, April 24, 2007 7:57 AM
alrght the fuse was blown. Thanks everyone.
the codes I have are P0420 Cat Low Efficiency and P0172 System Trim Rich
Tuesday, April 24, 2007 9:30 AM
Aha! Right again.
-Chris-
-Sweetness-
-Turbocharged-
