need opinions - Boost Forum
need opinions
Friday, April 06, 2007 8:34 PM
hey guys i have an 04 sunfire with a hahn stage 2 turbo kit but i reciently blew my motor...now i wanna no what would everyones perfect bottom end rebuild for boost and i wanna see like 15-18psi DD and what fuel mods would i have to get possibly afpr? what size injectors and that....
sorry for the noob question but i just got alot of money and i wanna no what would be perfect for 18psi DD
Re: need opinions
Friday, April 06, 2007 10:01 PM
What are you using for fuel management? Are you sticking with the FPR that Hahn Gave you?
I would go with Eagle Connecting Rods. Wiseco pistons (compression is up to you). Your stock crank is fine.
Did you have any cylinder wall damage? Scratches?
Injector size depends on the demand of fuel needed. There are injector sizing calculators that can help you get an idea of what size you'd want. How much power are you aiming for?
What size turbocharger are you running?
Do you have the proper monitoring devices?
What spark plugs are you looking to run?
Re: need opinions
Sunday, April 08, 2007 12:34 PM
fuel management i was thinking afpr with the fpr for tuning reasons
im not sure on the cylinder walla damage but i was gonna get it bored .020 over
injector size im not to sure i wanna rung 18psi DD with a 16 g turbo
I have a innovative lm-1 wideband also
and sprak plugs im not sure about......
Re: need opinions
Sunday, April 08, 2007 2:40 PM
clevitte bearings
arp main bolts (optional on the eco)
eagle rods
JE pistons
balanced/blue bottom end
that will be a strong bottom end.
Re: need opinions
Monday, April 09, 2007 9:22 PM
JE pistons are they better then weisco pistons?
