Hello guys,
For those who knew me, I am a 2.2 guy. I am new to the whole 2.4 thing.
I just finished installing the turbo on my 2.4. Now comes the MAP sensor deal.
I searched and found that one the cheapest way is to get a MAP off a supercharged GTP. But I have notcied that their MAP (the 2 or and the 3 bar) looks different than the one the 2/4 has. It is similar to the 2.2 MAP sensor.
ge-forcez22 said in one of the search results:
"if it is 3 wire in, 0-5 volt output, then yes. You may have to alterter the wires if everything checks out voltage wise."
Well, these are .2 - 5 volts.
Heres the link
http://www.alcohol-injection.com/advanced_search_result.php?keywords=map
PLEASE advice guys since it will take 4ever to get to me.
Gracias
get the msd map sensor, much easier to work with
LE61T PTE6262 Powered
Both the small and large style GM sensors work on a 0 - 5V signal. The large sensor is common on older vehicles like the gmc Syclone and the 91 or 92 Pontiac Turbo Grand Prix. You'll need a diagram showing 5V ref, gnd, and signal connections and you'll also need a connector and short bit of wiring harness to make it work.
Crossing over to the Dark Side, eh?
-->Slow
