read more about boost and you can understand why that is a really dumb question.
jcavalier wrote:y is that a dumb ?
off the top if my head, every car is different. build a 2.4 with 25 psi. dyno the car then come back and tell us
jcavalier wrote:what would a 2.4 run with 25 psi
25 psi built by somone asking this question
it would run itself into the ground
Did you not get the message? 25 psi on my 2.4 could be very different from 25 psi on your friends 2.4. There are countless little things that could throw the numbers one way or the other. Tuning, build-up, components used, etc. Just do it and find out.
To dumb it down - we can't tell you. That's the bottom line.
-Chris-
-Sweetness-
-Turbocharged-
lets do some dummy math.....
Stock 2.4 = 150hp
Average HP per PSI = 10hp (yea, I know......)
150 + 250 = 400.
Now, how long will a stock 2.4 hold up to 400hp, not long. Can 25psi = more then 250hp, yes....... but it can also equal less...... since its not the PSI per say that provides the HP, but the CFM the turbo (or other positive pressure device).
I know, but he wanted numbers......
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
I would make over 500 on 25psi.......
i had to say it.
-Trailblazer SS - not so custom 6.0L - custom intake - custom tune
- (1) 2.4L on an engine stand (1) blown trans (2) good quad trans (1) eco trans = party
jcavalier wrote:ok what is the most you can put in a 2.4 ? if you bib the right set up
Depends on your setup. Depends on bottom end. Depends on how many miles the motor had on it. Depends on your tune. Depends on how you break it in and drive it. There's no black and white answer to your extremely vague question. Is it beginning to click yet?
PUSHROD SQUAD
2200 OHV. 462 hp / 396 tq *RIP*
Abe Froman Video Productions on Myspace (click here)
Anywhere from 300 - 800hp.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Unless properly built. A 2.4 will make 0 hp at 25psi.
You need to understand that boost is a measure of restriction and nothing more. For example you could be running 15psi on a stock 2.4...you then change the cam and make no other changes to the engine, turbo or wastegate and your psi will drop just because there is less restriction in the system. The reason everyone is telling you that your question can't be answered is due to this fact.
Quoth the Raven 'Nevermore
raven@accesswave.ca
Raven Autosports
55 McQuade Lake Cres,
Halifax, Nova Scotia, Canada
(902) 850-3330
10.82@132
i have a 2.4l dohc and i have a universal turbo kit w/turbo mani off of ebay but i refuse to put it on until i have bigger injectors, bigger fuel pump, fuel rail, and personally if i was putting 25psi into a 2.4l i would HIGHLY recomend puting new internals in also or else you may blow your engine and without some bigger fuel delivery you will bog way down well thats just me and im sure some others will agree with me.....
