I bought a set of rods from egal, and I have yet to take them apart, but just looking at them, there isnt a break where it goes on to the crank. how in the hell does the bottom end come off?
you can see in this picture that there is no way to pull it apat? do Ihave to break out my dremel and custom make it.....
Kick azz is my boost hero!!!
newb lol....
unbolt the bolts and voila!
LE61T PTE6262 Powered
interesting, how that would be the first thing I would have done had I got the parts and questioned it.
Go Premium, it builds character!
It's like the small end, it uses a big-ass pin to hold it to the crank
Damn, that's a tight tolerance, very impressive.
14.330 @ 96.37mph
Lol common to the ppl who posted real replies, this is the same guy who said that turbotech was a couple of suckas for sending him a bunch of Cometic gaskets stuck together!
Got sarcasm? lol
<img src="http://memimage.cardomain.net/member_images/3/web/831000-831999/831395_11_full.jpg">
My rods weren't nearly that clean...I HAVE seen rods that weren't cut, but it was on purpose for demonstrations...
fortune cookie say:
Ben Brown wrote:Lol common to the ppl who posted real replies, this is the same guy who said that turbotech was a couple of suckas for sending him a bunch of Cometic gaskets stuck together!
Got sarcasm? lol
LOL the quality of the Eagle rods are really well done. The rod does almost look like 1 piece.
-Aaron
www.TurboTechRacing.com
Hack Saw
"Youth in Asia"...I don't see anything wrong with that.
Turbo Tech Racing wrote:Ben Brown wrote:Lol common to the ppl who posted real replies, this is the same guy who said that turbotech was a couple of suckas for sending him a bunch of Cometic gaskets stuck together!
Got sarcasm? lol
X2
I tought the same thing when I got my Eagle rods. WTF, where do they split???
We know Jason enough to know he's joking. He always did.
Gilles
2.3 Ho
Shifted wrote:Yup, undo those bolts at the bottom, and it comes apart. It doesn't look like there is a seam there, but there is, thats how well its manufactured
honestly.
I finnaly found the seem after breaking out my old magnifyling glass. that just gets me more exicted, Ive never seen rods that were so well cut,....... I mean yeah so I have only everseen used rods, but still there mad perty like.
who are you kidding, there is no cut there. break out the angle grinder
Blew it up, build numbers coming soon
Only real engine builders know that you're supposed to slip it over the crank with a super-secret, machinists only, slipper-jabber tool!
I've said too much...
Cardomain|
Myspace
i cna jsut barely see the seam
where?
P.S. Josh, Ive been trying to call, my guy can take off sunday or saturday, this weekend. I need to know what day.
You can see it between the bearing notchs and on the side of the rod.
Gilles
2.3 Ho
The sad part is that eagle rods for the ecotec have been discounted from eagle.
I called them the other day to get my order in and they only had 17 sets, and will make no more
So if anyone else is going to order them they better do it now.
Philly D wrote:huh??why??
Probably because of the 2.0 and 2.4 variants of the Ecotec
looks the same as my arctic sled, it goes onto a pressed crank... no bolts needed. Same rods I have, you will like them, just make sure you set everything in good bearind, studs, and oil, :cheers
wow that really sucks sorry to the op but were will be able to get new rods?? who other then eagle makes them? phil
if you retardes knew anything eagle cracks there rod caps not machines them. it gives them more strength. make shur you put them back together the same way they came apart or you just @!#$ your new rods.
