I finally got my NGKs in and gapped them at .35 to start with. I'll install them tonight and see how things are but wanted to see if anyone felt I should go lower?
I've read anywhere between .29 and .35 but nothing really fact only what folks felt worked best. I'm seeing 11 psi out of the charger and have a heat exchanger installed. Stock pulley as well so I'm running basic bolt ons with the GM ECO SC....
Thanks.
ive got the g/fs cav at .040 , stock is .045
her has the stock replacement ngk's iridum plugs
i ran mine at .040 on the new irriduims GM has never had a problem
Hello,
The correct plug for this vehicle one stage cooler in Iridium IX is the
LTR6IX-11 stock no. 6509. You may also want to consider reducing the gap from .044" to .035" to reduce spark blow out due to combustion chamber turbulence. Note: these are fine wire plugs and special care is required when adjusting the gap. Do not use anything that will pry against the center firing electrode as plug damage could result. TR6 and TR7IX are incorrect thread designs for this engine and should not be used.
Kristopher Zdral
Technical Support Representative
NGK Spark Plugs (U.S.A.), INC.
I run this and it runs perfect.
The ECOnator (Encriptor) wrote:Quote:
Hello,
Kristopher Zdral
I've heard the same thing about the LTR6...hrmmmmm....
I think I'll go at .35 and see what I come up with!
I run them at .29 but im at 14 psi.
Phlatcav wrote:I run them at .29 but im at 14 psi.
Yep...that's why I have them, you. I'll do what you said and we'll see.
Thanks for the help Aaron!
I have the same plugs and they are gapped at .028 or .029, i have not had any problems..... suncavi's advice, its been good so far, 15psi no problems.
Acer wrote:Phlatcav wrote:I run them at .29 but im at 14 psi.
Yup, hes where i got my info as well.
PS... SRT4 plugs made my car missfire like a mofo!
Phlatcav wrote:Acer wrote:Phlatcav wrote:I run them at .29 but im at 14 psi.
my old plugs were crap... these are love.
I kept mine at 0.044"...they seem to work fine.
^^^ I see more free horsepower. lol j/k
How could I tell if I'm misfiring or if my spark is being blown out?
youd have problems with the way it runs , and ses light flashing if the miss was severe enough
has anyone had trouble finding these plugs? i've been to autozone and advance autoparts and the employees have no idea what the hell i'm talking about. does someone have a link to where i can buy them online.
are
these the right plugs?
any help is greatly appreciated
http://www.sparkplugs.com/results_cross.asp?pid=LTR7IX-11&x=57&y=10
search sparkplugs.com for LTR7IX-11 and one result comes up, thats where i bought mine
at 7.60 a piece
i bought eight just in case.... the tips of iridium plugs are easily chipped so i didn't want to get screwed... luckily i didn't mess up and now i have 4 more for whenever i need to change my plugs out... no there not for sale
Did everyone gap theirs at .35?
I've not installed mine yet as I'm still going to replace my coolant and flush it all as well as add new thermostat and new coolant sensor after Christmas.
Mine have been gapped at .035 for a long while, No issues even at 15psi on the charger.
Whats the deal with these new plugs vs the srt-4 plugs? Or are they one in the same....
Airtonics wrote:Mine have been gapped at .035 for a long while, No issues even at 15psi on the charger.
Thanks!
I think these are the correct length where as the SRT plugs are a little short.
