H.O. injectors? - Boost Forum
H.O. injectors?
Tuesday, November 21, 2006 5:40 AM
Are the injectors out of the H.O. vin A and vin D engines 310 cc? I remember seeing something that said they were but can't find any additional information that suggests this might be true. Can someone tell me if they are and if it would be worth going and getting some (junk yard) for 8 lbs of boost? and obviously if they will be a direct fit to the 2.4 (2001) without the harness off the 2.3L
Re: H.O. injectors?
Tuesday, November 21, 2006 6:56 AM
I believe they are 270cc, and they are not good for boost.
Re: H.O. injectors?
Tuesday, November 21, 2006 7:27 AM
thank you for the quick reply. that will save me a trip to the junkyard today.
Re: H.O. injectors?
Tuesday, November 21, 2006 7:28 AM
What exactly are the size (cc) of the stock injectors on the 2.4
Re: H.O. injectors?
Tuesday, November 21, 2006 7:57 AM
252cc
Re: H.O. injectors?
Tuesday, November 21, 2006 8:55 AM
Ho injectrors are 32lbs/hr (around 335CC). They clip at 60psi.
Lo injectors are 27lbs/hr
Gilles
2.3 Ho
Re: H.O. injectors?
Tuesday, November 21, 2006 1:36 PM
^^^ yeah what he said
Re: H.O. injectors?
Tuesday, November 21, 2006 1:54 PM
H.O. injectors are also Low impedence. Your 2001 ld9 uses high impedence injectors.
32lb/hr would be fine for an unmodified motor running @ 8psi.
"Youth in Asia"...I don't see anything wrong with that.
