ok well i am only creating between 3-5psi with the 2.7 pulley. all depends randomness
2nd the transmission isn't kicking down into lower gears. but if i auto stick it it will change gears, basically it always leaves it self in the top gear
but floored with revs to 3k and then shifts to the next gear.
my vacuum is sitting at minus 20 at an idle, and the engine hunts a little.....
checked plugs and changed them. i am going to do a compression test but i dont think there is a problem with the engine it self. thinking it is the tranny
Sorry...
You have been banned from posting on this site as of 2005-09-21
00:33:32. This ban will expire 2005-09-28 00:33:32 Pacific Time.
Reason: Comments over the top regarding Jordan Kruger and other members in Versus. Also, if you have a problem with a member e-mailing you, do not bring it into the forums.
If you believe this to be in error, please contact us.
maybe your tranny is dirty....... change fluids and filter and see if that helps
Any one have thoughts and yes he knows he needs the stick
I can't believe you screwed up that car.........
I've got the stock SC pulley on and I am having a similar issue with my transmission. Mine idles fine, and I haven't confirmed the boost level but it seems to be having a hard time shifting. I've thought that it could be the belt slipping, but I haven't checked that yet. What size belt are you using with the 2.7", I'm putting mine on soon?
