Hi I dont knwo anything about turbos. Can someone tell me what AR Compressor turbine and TRim numbers actually mean. And also would this be a good turbo for a completely built 2.2L.
DESCRIPTION:
T3 T4 Turbo:
CNC Machined Flanges 4Bolt Designed fit most After market Mainfold.
High Quality TO4E, With Forged Turbine Profpelier Wheel
25 to 35 Psi Peak Power Performance Output Capability.
Designed Usable for internal Gate Applaction. And/Or Use A T3/T4 With An Internal Actuator.
3" Inlet Diameter w/ 2" Out Diameter.
Wet Floating Bearings 1/8 NPT Oilinlet.
T3/T4 Flange 4bolt fit most after market manifold.
TO4E TurboCharge SPec:
Turbine Wheel Excuder 2.48"
Mayor 2.89"
Compressor Wheel Excuder 2.07"
Mayor 2.36"
ComPressor Turbine Trim
50 A/R 63 A/R 57 Trim
