Team Vision Racing (aka hypsy) wrote:Teflon is expensive. If it ain't on the most expensive supercharged car they made, it ain't on the cheaper ones.
Jason wrote:I really doubt that it is Teflon. Here is a pic of some SC rotorsblower rotors, not SC rotors Although, you guys can keep calling them SCs if you want...for simplicity's sake
OHV notec wrote:Jason wrote:I really doubt that it is Teflon. Here is a pic of some SC rotorsblower rotors, not SC rotors Although, you guys can keep calling them SCs if you want...for simplicity's sake
mike wrote:so what about the guys running alcohol injection?
John Lenko wrote:Exactly... so, the GM S/C kits rotors aren't teflon coated... period.
But... they are epoxy painted... which still strips off with harsh cleaners apparently... one guy used GM Top End cleaner and apparently it made a mess of his rotors. I imagine the same would happen with Seafoam.....
I figure the epoxy paint is probably just fine with nitrous... but fuel? Gotta try it out, I guess....
Luke Heier wrote:I had the same thing happen to my stock FPR. It turned my S/C into a secondary gas tank. It didn't wreck anything, but what a mess. It took a while to get all of the gas out and finally get it to turn over.
Team Vision Racing (aka hypsy) wrote:"A supercharger is any device that pressurizes the air intake to above atmospheric pressure. Both superchargers and turbochargers do this. In fact, the term "turbocharger" is a shortened version of "turbo-supercharger," its official name."Hot damn, get off your high horse and pick up a textbook.
There's the punchline right there. Now go read before you post a reply.
OHV notec wrote:Team Vision Racing (aka hypsy) wrote:"A supercharger is any device that pressurizes the air intake to above atmospheric pressure. Both superchargers and turbochargers do this. In fact, the term "turbocharger" is a shortened version of "turbo-supercharger," its official name."Hot damn, get off your high horse and pick up a textbook.
1) NEVER did I state that a turbocharger is not a form of a supercharger, I'm not a friggin idiot...why don't you learn to read.
2) That page also says this: "The drive gear, in turn, rotates the compressor gear" along with the quote you posted above. Oddly enough, a roots-type BLOWER is not a compressor ('pressurizer' for those of you who can't correlate), as it does not compress the air within, therefore it can NOT have a compressor gear. A supercharger is a compressor, a blower is not a compressor. A blower introduced into a restricted system causes the SYSTEM to compress the air, but the blower is not a compressor...see how that works?
From dictionary.com:
"supercharger
n : compressor that forces increased oxygen into the cylinders of an internal-combustion engine"
A blower is referred to as a SC planely because over the years it has become common use, it does nothing to 'charge' the air on its own (charge=increase the energy of), it just acts as a fan and one-way valve.
I used to think of you as an alright guy Ryne, but you've been a real a-hole lately. Maybe time for a vacation or something.
Team Vision Racing (aka hypsy) wrote:1) I never said anything about you saying a turbo wasn't a type of supercharger. That was just a general add-in for those who don't know.Do you not read your posts when you type them???
Team Vision Racing (aka hypsy) wrote:"In fact, the term "turbocharger" is a shortened version of "turbo-supercharger," its official name."Good lord, you spent your post telling me I don't know something, and then you say you didn't say it...gimme a break
Team Vision Racing (aka hypsy) wrote:2) A supercharger is just a general term to denote anything used to compress air into a cylinder. So yes....a Roots-type is a SUPERCHARGER just because of the simply fact that it compressed the air going through it , whether or not it has a compressor gear. "That's the job of the supercharger. Superchargers increase intake by compressing air above atmospheric pressure, without creating a vacuum."It's not that it doesn't have a 'compressor gear', that was for emphasis on the point...which you apparently missed because you both agreed and disagreed with it in this section. To help you understand, I've underlined the part where you disagreed, and put the incorrect info in bold. It is incorrect because, just like I had finished explaining, it doesn't actually compress the air (if it sat in free air the air at the outlet would come out at the same pressure as at the inlet). The fundamental characteristic of a COMPRESSOR is missing from the roots equation. If you still don't get the point, nobody will be able to help you figure it out.
Team Vision Racing (aka hypsy) wrote:3) To add even more from that page, "The Roots supercharger is the oldest design. Philander and Francis Roots patented the design in 1860 as a machine that would help ventilate mine shafts. In 1900, Gottleib Daimler included a Roots supercharger in a car engine. As the meshing lobes spin, air trapped in the pockets between the lobes is carried between the fill side and the discharge side. Large quantities of air move into the intake manifold and "stack up" to create positive pressure. For this reason, Roots superchargers are really nothing more than air blowers, and the term "blower" is still often used to describe all superchargers. Roots superchargers are usually large and sit on top of the engine. They are popular in muscle cars and hot rods because they stick out of the hood of the car. However, they are the least efficient supercharger for two reasons: They add more weight to the vehicle and they move air in discrete bursts instead of in a smooth and continuous flow." What's this mean? THAT A ROOTS-TYPE IS A SUPERCHARGER. THE OLDEST AND LEAST EFFICIENT THERE IS, BUT A SUPERCHARGER NO LESS. It may do nothing but push a little air, or blow it as they say, but it still meets EVERY requirement to be a supercharger.You're pretty good at using the good ol' copy and paste functions, but your comprehension hasn't developed unfortunately Nothing you just posted does anything to disprove anything I wrote...However, you're statement that it meets every requirement is obviously flawed, as I've already proved. The only 'requirement' it meets is that people call it by that name. People also call Paris Hilton 'talented'...just saying...
Team Vision Racing (aka hypsy) wrote:4) Blower became the generic term for ALL SUPERCHARGERS because of the Roots-type characteristicsThats hilarious, I'd like to hear what makes a centrifugal SC anything like a roots? Besides the fact that they are both made primarily of a metal? and they both have a rotating assembly inside a concealed assembly with an inlet and exit? None of their operating characteristics are even remotely similar...
Team Vision Racing (aka hypsy) wrote:5) Frankly I don't care if you think I am an ass. Never have cared if anyone thought that now have I? I seem to get by just fine no matter what anyone thinks of me. If you don't like the way my posts sound then you have 2 choices...1) Don't read them OR 2) Read them a different way. Y'all make it sound like every post is evil or something. Go ahead and think that if you want though. Doesn't hurt me one bit.I said you were acting like an ass lately...get it right lol
6) Me proving you wrong, twice now, doesn't make me an @!#$. Just so we're clear on that too.
