Hey, i was just wondering how i would test for a boost leak on my car? is there a certain thing u have to do? or just see if everything is tight and check if your hitting the PSI you are supposed to be. thanks
soap and water is an easy trick that can point out leaks alot of times.........when i do it i spray small portions of the charge pipes at a time and rev the car to 3500 or 4000 rpm while looking at the places you sprayed....good luck......
