Im building my friends ecotec to handle about 15psi. He has most of the parts he needs already and the rest are on their way. The last thing I need to know is what head gasket should I be using?
the stock holds up fine no boosted cars have had a problem with it.
Yeah stock is the best... I know Jasmin went through 2 or 3 cometics because they would leak coolant... I just ehard of 2 more people with the same problem... the cometic leaks coolant....
Our stock head gasket is MLS 2 Layer.. it is very strong.... I will be running it under 15 pounds...
LE61T PTE6262 Powered
I've been running the Cometic for a while now with no problems. I've also got 4 customers running them without any problems.
5K PB: 24:50
10K PB: 54:26
.030 on my car
.074 on one customer
.036 on another customer
I forget the other two though.
5K PB: 24:50
10K PB: 54:26
Thanx alot guys. I recieved the motor tonight but wont start taking it apart for another couple weeks due to have having a couple other projects here that need immediate attention. I will keep everyone posted and snap pics along the way. Looking at the build sheet, its going to be almost like you build QBE, except for the cams.
Gimme a call if you need any parts man
I'll help you out.
5K PB: 24:50
10K PB: 54:26
Yeah, Chris has dealt with you, you come highly recomended
John H [Cavalierkid wrote:]currently running 15psi on a oem gm headgasket.
x2
gtpsunfire wrote:Yeah, Chris has dealt with you, you come highly recomended
Woohoo!
5K PB: 24:50
10K PB: 54:26
