What should compression be on 9.0.1? Need help ASAP! - Boost Forum
Saturday, September 23, 2006 11:51 AM
I have to do a compession check on my built 2.4 and need to know what the readings should be for 9.0.1.
Thanks'
Chris
Re: What should compression be on 9.0.1? Need help ASAP!
Sunday, September 24, 2006 9:55 AM
Around 130 PSI.
Sunday, September 24, 2006 1:01 PM
175-185, the stock 9.5 will net you around 205-225
according to the GM manual I believe it was any lower than 150 across all 4 is too low, and should be within 10 from side to side (on stock 9.5)
