hmm I keep looking through my price list and don't see the valve you're saying listed.... or maybe I just can't find it, I am still kinda tired from finals...
here you go chris. me and eric put this together a while ago...
Bracket, S/C Support, Lower 88960232 -121.98
Bracket, S/C Support, Top 88960233 -39.46
Duct, Intake Air 88960234 -142.06
Bracket, S/C Snout Support, Lower 88960235 - 39.46
Bracket, S/C Snout Support, Upper 88960236 -39.46
Bracket, Cruise Control Relocation 88960480 105.18
Plug, Inlet Air Temparature Sensor 88960479 - 1.98
Adapter, Intake Air Duct 88960237 -DISCONTINUED
Hose Clamp, Hose for Reducer 10039976 - 9.42
Hose, PCV, Baffle to Intake Air Duct 09436383 - DISCONTINUED
Hose, EVAP to Throttle Body 09438315 - 97.58
Hose, MAP Sensor to S/C 12387951 - 50.30
Belt, Accessory Drive 88960481 - 193.72
Tube, Brake Booster to Throttle Body 58960482 - DISCONTINUED
Flat Washer, PCV Bent Tube 94127883 - 1.04
Bolt, Nose Support, Upper to Lower 24503664 - DISCONTINUED
Bolt, Idler to Lower Nose Support 11515755 - 4.84
Bolt, Top/Bottom Bracket to Manifold 11515756 - 0.74
Bolt, Manifold Flange 11508476 - 0.86
Bolt, Bottom Bracket to Block 11515769 - 4.84
Spiral Lock Washer, Lower Bracket to Block 11500046 - 0.74
External Tooth Lock Washer, Upper to Lower Support 11501869 - 4.30
Spiral Lock Washer, Top/Bottom Brackets to Manifold & PCV Bent Tube 09439511 - 0.74
Spiral Lock Washer, MAP Sensor & Cruise 09439510 - 6.44
Nut, Cruise Control Bracket 03530297 - 1.48
Sensor, MAP 09350899 - 225.75
Clamp, 5/8" hose 10293740 - 4.84
Decal, Accessory belt routing 88960577 - 17.62
Injectors, Fuel 17113399 132.74 (EACH?)
Spark Plugs 05613717 - 2.66 (EACH?)
Decal, Fuel Use 88960578 - 13.32
Nylon flex loom, Hose PCV Elbow to Intake Air Duct 88960622 - 4.56
Barbed Hose Coupler, EVAP Hose to Rubber Elbow 88960623 - 8.32
Wire loom, Aire Temp Sensor Wire 12051375 - 38.34
Baffle Assembly, PCV 88960484 - 499.41
Seal, PCV Baffle 88894217 - 25.90
Actuator, Supercharger By-pass 88960487 - 163.78
O-ring, Throttle Body 88960488 - DISCONTINUED
O-ring, Intake Manifold Runner 88960489 - 39.56
O-ring, PCV Port 88960490 - 4.46
Grommet, Air Temperature Sensor 15705446 - 1.42
Clamp, Air Temperature Sensor 88960491 - 7.18
Bolt, Air Temperature Sensor and MAP Sensor Mounting 52368558 - 1.68
Bracket Assembly, Idler 12498289 - 267.22
Pulley, Idler 88960493 - DISCONTINUED
Bearing, Idler Pulley 88960581 - DISCONTINUED
