whats a good size of fuel injectors to use on a v6 - Boost Forum
Wednesday, September 13, 2006 10:56 AM
Hi Guys
I just want to know what is a good size fuel injectors to use in my turbo 3400? because I planed to run 8-10psi of boost.
Re: whats a good size of fuel injectors to use on a v6
Wednesday, September 13, 2006 11:03 AM
I would think a set of injectors from the 3.8 GTP motor would work but I could be wrong. Makes sense since that's a factory boosted motor.
Wednesday, September 13, 2006 12:54 PM
Injectors don't go by engine size, they go with the ammount of power your making.
Get an ammount of power you want to make then go from there.
Gilles
2.3 Ho
Wednesday, September 13, 2006 12:56 PM
Also goes by the number of cylinders
Wednesday, September 13, 2006 9:35 PM
Sorry...by number of cylinders, I was refering to number of injectors.
Friday, September 15, 2006 7:52 AM
well lets put it this way i am using the 36 lb whites from the gtp and come close to maxing them at the high rpm ranges (6500-7000)
i am running 7-10 psi. this is a heavily modded 3100, cam, heads, headers, 60-1 comp. 82 ar t3.
farmerz24
