Update on turbo project (98 2200) - Boost Forum
Saturday, September 02, 2006 2:36 PM
Just posting an update on my turbo project. I recently removed the header to mock the turbo manifold to make sure I wouldn't have any fitment issues. Also I installed the efi unit, 2 bar map sensor for the programmable msd ignition and ran the vacuum lines for the efi controller and ignition. The rest of the project is pretty much straight forward and just involves installing a down pipe, wiring the efi controller, fabricating a charge pipe with secondary injectors, bov and iat sensors. I'm currently waiting for a backing plate for the turbo, than that will get installed with the oil lines.
Here are some pics of the project so far:
............super 60 on its way
Re: Update on turbo project (98 2200)
Sunday, September 03, 2006 12:56 PM
nice!
Sunday, September 03, 2006 11:19 PM
nice.....
get another intake mani.... those plastic ones like to blow up if your fuel set up in those extra injectors isn't perfect................(puddling)
and it says 200 whp or bust..... 8 - 10psi should do.... with a 3" exhaust and a couple other small things.....(crank pulley, flywheel.....)
Good luck
Lee
JDM Civic Hatch
