Who's using MSD w/GM s/c setup. - Boost Forum
Wednesday, August 23, 2006 5:49 PM
Who's using msd with gm s/c setup and have it actually work to get rid of the misfire under boost.
Nate
1995 Cavalier W/2k1 Engine
Re: Who's using MSD w/GM s/c setup.
Friday, August 25, 2006 4:17 PM
Heh... well, you know me Nate.... I was using the MSD you bought from me... never had any misfire problems.....
Other problems... yes.... but not misfire
Tuesday, August 29, 2006 4:31 PM
I'm not having any misfire issues on my car and i'm only running 2 steps colder plugs and stock ignition for now. I'm not sure about the MSD, i thought about getting one and doing the coils but heard it wasn't really going to be beneficial.
"Horsepower is the Ultimate Accessory"
Tuesday, August 29, 2006 4:45 PM
An MSD wont cause or cure a misfire
Im not running the gm setup but I do have a supercharger and the msd, I used to have a misfire, since I went to the 310cc injectors no misfire at all, I tried 3 diff types of plugs at gaps all over the map and none of them caused or cured the problem, mine was simply caused by too lean of a AFR
