oil tap question - Boost Forum
oil tap question
Tuesday, August 22, 2006 7:34 PM
OK well i did a search and couldnt find a postive answer. I have read in a couple of posts that some people are having difficulty drilling the oil pan the right size. now I have the HAHN Stage 2 Kit for my 2002 Eco Cav. The manual says i need to make a 3/8NPT tap. i am just double checkin but is htis correct before i drill? cause i have read that some people are using a 1/2NPT tap. so any help would be awesome. thanks
<img src="http://www.j-body.org/registry/cav13/Chris-Cav-004.jpg">
Re: oil tap question
Tuesday, August 22, 2006 7:42 PM
I fell obligated to help you
yes its a 3/8 npt tap. make sure you test fit on the car before fial install. good luck
"Kick azz is my boost hero!!! "
Tuesday, August 22, 2006 7:57 PM
The TAP is 3/8NPT. That IS NOT the drill size. DO NOT drill a 3/8in hole. Go buy a 3/8NPT tap and get the recommended drill bit for it at the same time.
5K PB: 24:50
10K PB: 54:26
Wednesday, August 23, 2006 5:34 AM
thanks, exactly what i needed to know.
