alky injection and tps problems, solutions? - Boost Forum
Friday, August 11, 2006 8:42 PM
well i yet again messed up another tps with my alky injection as i knew would happen, i was hoping to get a few track runs before it went but it happened before the track tonight. I take the intake tube off and its filled with water droplets so i turn the engine on and rev it up to where the alky is spraying and i see a mist come out but some big water drops dripping out after the mist which tells me i THINK im using too much water in my mix. Im filling a half gallon jug halfway with water and the rest heet so ive come to the conclusion of either using 100% meth (heet) or X amount of water but not enough to drown out my tps, also whats the truth to about methnol damaging the charger? Now i know josh and everybody tells me to use a t/b plate to bypass the tps problem but would my conclusions work also? buying the plate is no big deal but just figured if i could do this w/o using the plate then thats good also. the tps i found at advance auto has a 3 month warranty on it so if i drown it out no biggie ill take it back and get a new one for free within the 3 months.
Re: alky injection and tps problems, solutions?
Friday, August 11, 2006 8:51 PM
what size injector you using.
Friday, August 11, 2006 8:55 PM
m5
Friday, August 11, 2006 9:50 PM
damn that is why
try a m3 and i bet u dont have a problem.
go to www.mcmaster.com
search "brass misting nozzles" / page 1939
look for standard nozzles/standard cone spray.
size it up under GPH@100 PSI.
so 3.0 is a M3.
8$ shipped
